Old 23-12-2007, 02:19 AM   #1 (permalink)
Default Need creative sound blaster live 5.1 vista drivers??
Creative seems to have dropped this sound card.Plz help me i couldnt find drivers fo vista.
piyush1989kap is offline
Old 23-12-2007, 02:50 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Need creative sound blaster live 5.1 vista drivers??
run an Auto update... Microsoft VIsta update service it self contains the largest Driver bank for any OS at present.. so give it a shot, see if it helps or not...
thnx..
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 23-12-2007, 08:59 PM   #3 (permalink)
sidewinder's Avatar
try installing xp drivers...i use audigy value and xp drivers worked perfectly
Bombina rocks
sidewinder is offline
Old 23-12-2007, 09:30 PM   #4 (permalink)
i also have the same card and it isnt compatible with vista i think.
i also tried updating vista but still cudnt get it to work .then i had to go with onboard sound card.
SunnyChahal is offline
Old 24-12-2007, 06:06 PM   #5 (permalink)
99.9% Idle
axxo's Avatar
heh..i have the drivers for both vista x86 and x64 that works...if you want i can upload it.
axxo is offline
Old 14-06-2008, 09:55 PM   #6 (permalink)
@ axxo
can u provide me the links?
mrbgupta is offline
Old 14-06-2008, 10:09 PM   #7 (permalink)
99.9% Idle
axxo's Avatar
http://rapidshare.com/files/50870866..._2_15_0002.zip
axxo is offline
Old 15-06-2008, 03:21 AM   #8 (permalink)
johnjjx's Avatar
They r available jus go to paxx.org. Dun rem exact name of site google it. It has links to al creative drivers, softmods etc
e8400 / abit ip35-E / gskill 4gb / mx5021 + audigy 2zs / Visiontek 4870 / corsair vx450 / Dell E198wfp
johnjjx is offline
Old 03-01-2009, 08:25 AM   #9 (permalink)
Dear Axxo,Thanks so much for that upload...
Googled so much and couldn't find something as perfect as the one you have provided.
Thank You
uniquegodwin is offline
Sound Blaster Live / Audigy vs Realtek ALC860 7.1 Kannan QnA (read only) 7 27-06-2006 11:03 PM
Drivers for Creative Live 24bit sound card. Nikhilsam Open Source 2 01-02-2006 02:18 AM
CREATIVE SOUND BLASTER 5.1 naveen_reloaded QnA (read only) 6 14-01-2006 12:21 PM
sound blaster live 24 bit yogi7272 QnA (read only) 5 16-11-2004 01:30 PM
