Old 22-12-2007, 03:18 PM   #1 (permalink)
Default Folder Lock big problem
hey any one knows how to fix this problem. I recently downloaded a full version torrent of folder lock 5. something and I locked my very important folder in D:\ drive the path is D:\saaif and I unlocked it when needed but today when I tried to unlock the folder the folder is gone from the unlock window and couldnt unlock the folder. ummm any help please??
vi00097 is offline
Old 22-12-2007, 03:26 PM   #2 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
Default Re: Folder Lock big problem
Anyways I don't think there is any other method except for trying your luck with that software again.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 22-12-2007, 03:29 PM   #3 (permalink)
what do you mean?
vi00097 is offline
Old 22-12-2007, 05:04 PM   #4 (permalink)
Try using that software in SafeMode.
ico is offline
Old 22-12-2007, 06:18 PM   #5 (permalink)
some versions comes with password resetting reg file or something like that.
temperworld is offline
Old 23-12-2007, 06:50 PM   #6 (permalink)
uninstalling and reinstalling dosnt help. and no reg file found.
vi00097 is offline
Old 23-12-2007, 08:41 PM   #7 (permalink)
chahal63's Avatar
Smile Re: Folder Lock big problem
JUST try the only ramban ... i mean if your file is too important just format c drive and reinstall your window and then reinstall your software if you have your file in c drive then only god can help you
chahal63 is offline
Old 23-12-2007, 08:57 PM   #8 (permalink)
Hey thanks I didnt format my any drive but I dont know how that folder appeared but thanks in load because a worth $500 softwares are saved.
vi00097 is offline
Folder lock problem, how to unlock? besteast Software Q&A 48 08-04-2010 11:23 PM
Folder lock???? smile Software Q&A 6 15-12-2007 03:28 PM
Folder Lock Problem Nikhil Vora Software Q&A 5 21-10-2007 05:39 PM
Folder Lock? Lord Vader Software Q&A 14 22-11-2006 08:57 AM
Folder lock problem!! yrana2002 QnA (read only) 1 09-10-2005 06:07 PM
- by chris
