Old 22-12-2007, 02:57 PM   #1 (permalink)
rahul_jaiswal31's Avatar
Default Partitioning d Hard drive
hi frendz
i want to resize & delete the partition of my hard disk & portable hard disk.
Please suggest me a handy & free utility as i am doing it 1st time.
Thanks In ADVANCE.
rahul_jaiswal31 is offline
Old 22-12-2007, 06:40 PM   #2 (permalink)
Default Re: Partitioning d Hard drive
Originally Posted by rahul_jaiswal31
hi frendz
Thanks In ADVANCE.
If you are regular reader of Digit, then you can find your solution in this month DVD. There is a tool called UBCD (Ultimate Boot CD) which is bootable and in this DVD you can find some user friendly tools that help you to format and part your hard drive.
And if you are not a regular reader of Digit, then you can try Seagate Disk Manager v. 10 either from Seagate website or you can search the link from Google.
goldy_connect is offline
Old 24-12-2007, 10:56 AM   #3 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
try gparted = http://gparted.sourceforge.net/ .......
easy 2 use ......
... W H O T ...
ax3 is offline
Hard Drive Partitioning- XP Home Edition s18000rpm Hardware Q&A 4 15-07-2006 09:32 PM
Hard Disk Partitioning Generic Superhero Software Q&A 5 06-05-2006 04:47 PM
hard disk partitioning using cylinders?????????? taran00 QnA (read only) 2 27-06-2005 11:09 AM
SATA hard disk partitioning and formatting godblessedson QnA (read only) 5 24-06-2005 09:30 PM
- by chris
