Old 19-12-2007, 10:44 AM   #1 (permalink)
nach p's Avatar
Default Waves on Monitor & Reboot prob
My friend getting waves on his monitor.Is it software problem or Hardware ?
& Even after clicking on Turn Off PC gets restarted.
Wht can be a prob.
thnx
"UNIX is basically a simple operating system, but you have to be a genius to understand the simplicity."
-Dennis Ritchie
nach p is offline
Old 19-12-2007, 10:47 AM   #2 (permalink)
Default Re: Waves on Monitor & Reboot prob
Try changing the refresh rate of the monitor to 75 or 85 hz
cool_techie_tvm is offline
Old 19-12-2007, 01:35 PM   #3 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
degauss it ....... check ur monitor 4 this .....
remove speaker placed next 2 ur monitor ....... or any magnetic THING .......
... W H O T ...
ax3 is offline
Old 19-12-2007, 08:42 PM   #4 (permalink)
nach p's Avatar
Changing Refresh rate fixed the problem of monitor
But yet restart prob is not resolved.
-Dennis Ritchie
nach p is offline
Lcd monitor prob rohus24 Hardware Q&A 5 18-06-2007 10:54 PM
Waves!! cooldip10 Hardware Q&A 6 15-06-2007 05:46 PM
Waves like kumarn_2004 QnA (read only) 5 26-02-2007 06:17 PM
Waves like. kumarn_2004 QnA (read only) 1 24-02-2007 10:32 PM
Prob with resolution of monitor cyrux QnA (read only) 1 25-01-2006 06:44 AM
- by chris
