Re: firewall installation help!
First of all XP SP2 has its own firewall which is turned on by default, unless you decide you do not want it. When you install your torrent client for the first time it attempts to communicate through the firewall and you get a prompt, asking you for permissions (unblock program). You have to allow access, then you're set. If you want to install a third party firewall then its a different kettle of fish. For example, ZoneAlarm Free gave me hell on earth with torrents even though I granted access.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
