Old 14-12-2007, 12:08 PM   #1 (permalink)
Default folder on usb drive inaccessible on changing computer
i have 4 laptops
one extra external 2.5inch laptop hard-disk in usb casing
i use that HDD in all 4 lappy
it often happens that i paste or save on my external hdd, but when i plug it into other lappy, i cannot access those folders
error message says : folder is inaccessible / access denied
what do i do ?
neilsatyam is offline
Old 14-12-2007, 01:07 PM   #2 (permalink)
smile's Avatar
Default Re: folder on usb drive inaccessible on changing computer
Scan it ...... i think its a virus problem
SR
smile is offline
Old 14-12-2007, 01:59 PM   #3 (permalink)
scanned with panda 2008 and kaspersky 2006
no use
is my laptop infected or usb hdd?
when i plug my usb hdd in any other computer, i m not able to access some files/folders i pasted or saved on my hdd while it was plugged into some other laptop
when i plug it back into that laptop, i can access.. so only laptop which saved or pasted can access that folder
in rest, some pasted folders are accessible while some inaccessible.. the inaccessible ones are shown as zero byte file and when i plug it back into the laptop where i has pasted, it works
Old 14-12-2007, 02:06 PM   #4 (permalink)
Deadman Walking
Batistabomb's Avatar
Take owner ship of folder :
How to take ownership of a folder
Note You must be logged on to the computer with an account that has administrative credentials. If you are running Microsoft Windows XP Home Edition, you must start the computer in safe mode, and then log on with an account that has Administrative rights to have access to the Security tab.
If you are using Windows XP Professional, you must disable Simple File Sharing. By default, Windows XP Professional uses Simple File sharing when it is not joined to a domain.
For additional information about how to do this, click the following article number to view the article in the Microsoft Knowledge Base:
307874 (http://support.microsoft.com/kb/307874/) How to disable simplified sharing and set permissions on a shared folder in Windows XP
To take ownership of a folder, follow these steps:
1. Right-click the folder that you want to take ownership of, and then click Properties.
2. Click the Security tab, and then click OK on the Security message (if one appears).
3. Click Advanced, and then click the Owner tab.
4. In the Name list, click your user name, or click Administrator if you are logged in as Administrator, or click the Administrators group. If you want to take ownership of the contents of that folder, select the Replace owner on subcontainers and objects check box.
5. Click OK, and then click Yes when you receive the following message:
You do not have permission to read the contents of directory folder name. Do you want to replace the directory permissions with permissions granting you Full Control?
All permissions will be replaced if you press Yes.
Note folder name is the name of the folder that you want to take ownership of.
6. Click OK, and then reapply the permissions and security settings that you want for the folder and its contents.
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
Batistabomb is offline
Vista - Folder Name Changing Problem Ashok Kumar SN Software Q&A 2 31-10-2007 07:11 PM
Changing Drive Icons. How? s18000rpm Software Q&A 11 09-11-2006 08:49 PM
The strange inaccessible Ricky Software Q&A 4 12-08-2006 01:25 PM
Changing bios , for wake up Computer, main board D845GVSR eureca_eureca Software Q&A 7 26-12-2005 07:40 PM
Can any one help . . .Changing folder icons . . . jay4u Software Q&A 4 10-04-2005 11:15 AM
- by chris
