Re: System having a big problem
smile try Avast Antivirus which is free downlodable from avast site, after you registered you will be recieving a key, if your's broadband always keep avast on taskbar tray so that daily 1 new definition is updated, which will protects you in 6 ways
After installing perform only boot scan, because you can verify and delete the virus handy, only delete not delete all
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
