Old 06-12-2007, 03:39 PM   #1 (permalink)
TechFreakiez.com
Abhishek Dwivedi's Avatar
Default dedly virus..plz help...**urgent**
guys...i need a serious help....
Am using Windows Vista home basic...
I've just got infected by a virus names FUNNY UST SCANDAL.avi
when ever i open yahoo...it starts controling ma mouse...i can't use ma mouse at dat time...its disbled to view hidden files on ma system...
it even tries to send itslf to other yahoo members n sends stupid senceless msgs to yahoo users...
I've scaned ma sys by NIS 2007 updated but gud...
plz help...
And ya...BEWARE
i think i've got da solution...
1) Scan ur registry with sum good registry scanner.
2) Uninstall Yahoo messenger.
3) Search for FUNNY UST SCANDAL.avi files and delete them.
4) Look for the FUNNY UST SCANDAL.avi at C:\windows and delete it
5) Scan your system with antivirus.
This might remove the virus as when i did all dis...everything got back 2 normal but still dat hidden file stuff is not wrking so expect da virus 2 b hiding sumwhere...
Can ne one hlp with da hidden file enable stuff??
Personal Log | Star date 05.04.2009: TDF Meet Kanpur was Awesome :D
www.TechFreakiez.com
Last edited by Abhishek Dwivedi; 06-12-2007 at 03:39 PM. Reason: Automerged Doublepost
Abhishek Dwivedi is offline
Old 06-12-2007, 03:44 PM   #2 (permalink)
!! RecuZant By Birth !!
naveen_reloaded's Avatar
Default Re: dedly virus..plz help...**urgent**
Use standard av like nod32 or use bit defender..
Or else use avg av which is free.yöü can also try adaware..and spybot search and destroy.
Know My Thoughts..
Visit my Blog @ www.Urssiva.com
Visit My Tech Blog @ www.CloudTechnica.com
naveen_reloaded is offline
Old 06-12-2007, 03:57 PM   #3 (permalink)
Do an online scan of your pc using kaspersky. That should find the culprit.
A word of advice, uninstall NIS 2007. Switch to something that really works.
cool_techie_tvm is offline
Old 06-12-2007, 04:02 PM   #4 (permalink)
TechFreakiez.com
hmm...u guys damn sure dat NIS 2007 is crap??? well i've got a original one installed
Old 06-12-2007, 04:09 PM   #5 (permalink)
TheSaint
NucleusKore's Avatar
Here are the instructions
http://upgrayded.blogspot.com/2007/1...-manually.html
Quite elaborate, but at the end of the post there is a automatic removal tool
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 06-12-2007, 08:34 PM   #6 (permalink)
TechFreakiez.com
thx buddy...
Old 06-12-2007, 08:36 PM   #7 (permalink)
TheSaint
You're welcome
Old 08-12-2007, 02:03 PM   #8 (permalink)
TechFreakiez.com
alright NucleusKore...dat tut u gave was really nice but da problem is dat am on Vista n dat structure of Vista is very different frm XP n dat tut is for XP users...lolz...well i've got da stuff out but still 2 problems still remaining...
1) I can't unhide da hidden file (only cmd is hlping me do so...i need dat folder option on unhiding file to wrk)
2) Dere is a file name FUNNY UST SCANDAL.AVI.EXE in C: n F: but i can't c dem thru Windows Explorer....when i type DIR/A in cmd, den it shows da file but gives an error or invalid parameter when i try to do dis attrib FUNNY UST SCANDAL.AVI.EXE -h -s. How do i delete these files???
Old 08-12-2007, 04:04 PM   #9 (permalink)
Bitdefender ll solve it easily
navisangha is offline
Old 08-12-2007, 06:38 PM   #10 (permalink)
TheSaint
Sorry I don't know, did you try the remover they posted at the bottom of that page
Old 09-12-2007, 09:35 AM   #11 (permalink)
tweety_bird_bunny's Avatar
to unhide,,
go in registry hkey_local_machine/software/microsoft/windows/currentversion/explorer/advanced/folder/hidden
there under hidden/nohidden folder, click on it on right side, check dat values of checked value & default value must be 2.. if not then click on them and change it to 2..
next under hidden/showall folder..click on it..on the right side, checkedvalue1 , defaultvalue=2 should b there..if not make the changes...exxit registry n try again
tweety_bird_bunny is offline
Old 09-12-2007, 09:23 PM   #12 (permalink)
I had this virus earlier. I booted to ubuntu and I searched entire HDD for all *.exe files and sorted by file size. This virus exe has a size of around 226 k or something I guess. Just delete all exe files with that file size. These files will have that stupid "AVI" icon also.
Reboot back to windows, and do the registry thing to enable showing hidden files, and u shud be done.
If u dont have linux installed, try some live-cd version.
gulgulumaal is offline
Old 09-12-2007, 10:06 PM   #13 (permalink)
TechFreakiez.com
k...i'll try da linux...i've got fedora 6...lets c find out...thx bro...n thx Tweety_bird_bunny...
Old 10-12-2007, 07:41 AM   #14 (permalink)
TheSaint
How about Open SuSE 10.3?
virus problem very urgent raysoni_r Software Q&A 4 22-01-2007 08:25 PM
[urgent] Infected by a virus...please help! ApoCalypse Software Q&A 2 31-03-2006 12:50 AM
Virus ! Need urgent help to remove it. Tech&ME Software Q&A 6 03-03-2006 07:28 PM
Urgent Help...virus...? gdatuk Mobiles and Tablets 2 10-09-2005 11:44 PM
VIRUS...RANDEX ZEN.......VIRUS MLORE HELP..??URGENT Writankar panja Software Q&A 9 19-09-2004 05:26 PM
- by chris
