05-12-2007, 10:10 PM
CG Artist
Why my system/window is hanging?
I am using windows xp.And its hangs for the first time i run it everyday.Then i have to restart and then it works fine.Why is it so?But today it has hanged three times already  Jaldi batao bhai logon.  Windows baar baar dalne pe bhi yeh problem ho rahi hai.
05-12-2007, 10:17 PM
Re: Why my system/window is hanging?
HDD problem lagti hai, check them
05-12-2007, 10:23 PM
When windows starts after a force turnoff do this:
start/run/"eventvwr"
click system and figureout the error nd post the discription curresponding to red alert marks, here. Well try to fix it.
G3: XPS M1530 |
FZ 16.
05-12-2007, 10:29 PM
NP : Crysis
i'd say the prob lies in the fact that it is windows
05-12-2007, 10:47 PM
Could be a HDD issue!
speedrider - The ultimate
05-12-2007, 10:59 PM
The Devil's Advocate
if u have re-installed windows and still face the same problem it is likelyit is because of some hardware or driver
http://beingmanan.com
05-12-2007, 11:02 PM
CG Artist
here it is
Time Provider NtpClient: An error occurred during DNS lookup of the manually configured peer 'time.windows.com,0x1'. NtpClient will try the DNS lookup again in 15 minutes. The error was: A socket operation was attempted to an unreachable host. (0x80072751)
another
The DS1410D service failed to start due to the following error:
The system cannot find the file specified.
05-12-2007, 11:07 PM
@gaurav_indian
some network configuration prob.
Try installing comodo firewall. Itll block all thirt party apps from accesing nd editing network configurations like DNS setings etc.
Do ya have static or dynamic ip?
G3: XPS M1530 |
FZ 16.
05-12-2007, 11:09 PM
CG Artist
@gaurav_indian
I have dynamic ip.
But aravind it happens whenever i run the window for the first time.And maine toh net bhi nahi chalaya tha.
05-12-2007, 11:10 PM
try removing ny lan card or dun install the lan drivers or if possible try disabling the lan.
also go to;
my computer>properties/advanced/startup n recovery/ and uncheck 'automatically restart'
see if somethis is displayed on the BSOD.
see if there is ny probs with the file[on the BSOD if any]
ndis.sys in windows/system32/drivers
G3: XPS M1530 |
FZ 16.
06-12-2007, 05:18 PM
troubleshooter
I think removing LAN card it should work
OR disable LAN card from BIOS setup
06-12-2007, 10:58 PM
CG Artist
hmm but main internet kaise chalunga phir?
06-12-2007, 11:04 PM
die blizzard die! D3?
abe oys just reinstall na whats the problem in reinstalling?
And better get Vista now.Mine is for same if you need....
Stealing your women and horses since 1843.
06-12-2007, 11:05 PM
CG Artist
kya reinstall karu?Window xp?Yaar window install karne pe bhi 2-3 din theek chalta hai then same problem.Vista original buy karne ke abhi paise nahi hai.
06-12-2007, 11:12 PM
TheSaint
Please change the slot of your LAN card
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
^^hmmmm..
yaar this shouldn't happen na you know works 2-3days all right and then starts giving BSODs.
I meant try vista and see if it happens or not.You can officially try Vista---it'll install without any key and you can try it for 30 days.
Can't suggest you ubuntu cos you need to work on photoshop extensively.Though wine+photoshop is worth giving a try.
06-12-2007, 11:14 PM
CG Artist
Its onboard.
^^hmmmm..
yaar i cant try vista now.  iska solution batao roj roj new problem
Reason: Automerged Doublepost
TheSaint
 ok, not possible. I was thinking in terms of an IRQ conflict. I guess you'll have to reinstall
06-12-2007, 11:18 PM
#19 (permalink)
CG Artist
How can i get a log of all the files that are causing window xps to hang?
I have tried eventvwr yesterday it was showing the error which i have mentioned in my above posts and i have solved that.But this time there is no error in the eventvwr.I want to know whats causing my xp to hang may be that will help.
06-12-2007, 11:20 PM
#20 (permalink)
TheSaint
I really do not know. We have to ask our MVPs Vishal and AnandK
06-12-2007, 11:21 PM
#21 (permalink)
Web developer
any recent software/driver installation/updation? if not scan your hdd for bad sectors
06-12-2007, 11:22 PM
#22 (permalink)
CG Artist
I have send a pm to vishal gupta.He didnt reply.
#23 (permalink)
^^I think your hardware is at fault.
try checking memory(RAM) for errors or try reinstalling them,remove and reinsert HDD cables.what else?
#24 (permalink)
@gaurav_indian
do ya use ny torrent clients?
G3: XPS M1530 |
FZ 16.
06-12-2007, 11:24 PM
#25 (permalink)
CG Artist
@gaurav_indian
no.
yaar fault kahan hai wohi toh i am asking.
06-12-2007, 11:25 PM
#26 (permalink)
yaar ubuntu livecd hai?Then you can test your memory for errors through this.
Check your hard disk for bad sectors.And kitni baar reinstall ki hi windows?I mean just reinstall one more time,install your drivers and then work for some time on this naked install and see if the problem persists.SOunds like hard work eh?
I think your external hard disk is going crazy.lol.Sell it off to me.
07-12-2007, 12:12 AM
#27 (permalink)
CG Artist
No i havent installed/updated any software.
It hanged again after working for 1 hour.
07-12-2007, 12:15 AM
#28 (permalink)
Web developer
buddy scan for bad sectors & check your ram for problems & check all the cables, processor fan, smps, smps fan etc.
07-12-2007, 12:16 AM
#29 (permalink)
left this forum longback
this can be a memory problem.u shud try with another ram.also make sure ur win partition can afford pagefile.sys size
07-12-2007, 12:21 AM
#30 (permalink)
I told him its most prolly mem problem them.
ye le link : http://www.memtest.org/
