Old 04-12-2007, 07:21 PM   #1 (permalink)
Default Need urgent help...My pendrive not detecting...
Guys..I have a 2gb transcent pen drive which is not detecting by my xp from today morning...the pen drive is detected by other computers.I think its a virus problem..I am not able to unhide my hidden files and show the system files..i am running avast home and spybot search destroyer updated with latest def.
Help me out dudes.....
yoursnayak is offline
Old 04-12-2007, 07:29 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Need urgent help...My pendrive not detecting...
Injack pen drive in nany USB-->> right click my computer-->>properties-->>hardware-->>device manager.
Find any with ? mark in USB string.
Right click and select update driver.Let windows update the driver it self.
This should solve your problem.
Also try your pen drive in other USB pots on your system.
ravi_9793 is offline
Old 04-12-2007, 07:37 PM   #3 (permalink)
Smile Re: Need urgent help...My pendrive not detecting...
I tried all that....its still not detecting....
Old 04-12-2007, 07:39 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
try any other pen drive on that USB port.
Also try changing USB port on your system.
Old 04-12-2007, 07:49 PM   #5 (permalink)
no dude...no other pen drives are detecting in my system..i 've one more xp installed in my system where my pen drive is detecting!...thats y i am thinking its a virus attack....
Old 04-12-2007, 08:23 PM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
Than it is issue with XP.
Solution
Before you start...make a restore point.
1)Start-->>Run-->> type regedit and press enter.
2) Windows registry page will open.Navigate to here:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E980-E325-11CE-BFC1-08002BE10318}
3) In right pane find UpperFilters -->>right click-->> Edit-->> Delete-->>OK.
4) Navigate to here:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E967-E325-11CE-BFC1-08002BE10318}
Find LowerFilters in right pane-->>edit-->>delete
Exit registry-->> restart system-->> Done!!
Old 22-06-2008, 03:50 AM   #7 (permalink)
hey what do you mean by upper filters and lower filters.....i am facing the same issue....my pendrive and external harddisk both are not getting detected....
walky is offline
Old 15-01-2009, 04:02 PM   #8 (permalink)
Exclamation Re: Need urgent help...My pendrive not detecting...
Hello friends.....
I am in a real deep trouble. Recently I found that my pen drive is not being detected on my laptop. Take any pen drives, for eg - Transcend, iBall, Kingston, but its detecting my 2gb Philips GoGear MP3 Player. And yes I checked my MP3 Player on all of my USB port. Only Pen drives aren't working. They are working fine on other systems.
My Dell Inspiron 1525 Laptop configuration is Intel Core 2 Duo (2.0ghz) 2gb RAM 160 gb Hard disk with Windows XP SP2.
Anti-Virus is Mcafee Enterprise edition 8.5i
I had disabled auto-play option on all my drives using Powertoys for Windows XP - Tweak UI. I tried enabling Autoplay also. But it didn't worked.
Also tried the above Registry editing option also. But failed to dind Upper and Lower filters. And also failed to create Restore point.... getting a message even after restarting system : "System Restore was unable to create a restore point. Please restart your computer and run System Restore again."
Please help me soon.
thanks in advance
Last edited by abhijeetsingh07; 15-01-2009 at 04:15 PM. Reason: Automerged Doublepost
abhijeetsingh07 is offline
which is the best pendrive? max_demon Hardware Q&A 44 06-12-2009 07:30 PM
HDD not detecting FunkyB Hardware Q&A 5 03-05-2007 09:37 PM
Wmp 11 Not Detecting Cd - Writer ayushman9 Software Q&A 5 11-02-2007 11:27 AM
Urgent-:cd Writer Not Reading/detecting High Speed Wrriten Discs ayushman9 Hardware Q&A 3 05-11-2006 08:52 AM
- by chris
