Old 04-12-2007, 05:31 PM   #1 (permalink)
never forgot your roots!
Default problem with "Sytem Vol......." help me??
Hi ! friends i hv a problem . i hv all my drives formatted in NTFS. as FAT n NTFS make their system folder called "System Volume Information ". some times when i delete some data from the drive instead of deleting it goes into that folder i.e., System...." now we can open the that system folder in FAT system n in NTFS we r not able to access that folder. so today i delete data of 267 MB size n it occupies space in system folder n disk space is not freed so my problem is that how can i remove that data from System folder. in last couple of times i format the drive to delete that ....after making it empty .so this tiem i don't want to that things again.
plz tell me why this happen to me 'n' how can i get rid of this 'n' i don't want to format the partition into FAT.plz help me.
hello some one ans yaar!its a problem for me!
SUKHI99 is offline
Old 04-12-2007, 07:05 PM   #2 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
Default Re: problem with "Sytem Vol......." help me??
tried emptying recycle bin?
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 04-12-2007, 07:15 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
right click on that drive-->>properties-->>and do disk cleanup-->> select all files type-->>delete all.
ravi_9793 is offline
Old 04-12-2007, 07:28 PM   #4 (permalink)
i hv tried disk cleanup already ! thank for the suggestion! plz tell me anyohter way coz it doesn't deleted using disk clean up!
and my recycle bin is already OFF!
SUKHI99 is offline
Old 04-12-2007, 07:35 PM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
are you sure..disk cleanup doesn't clean disk.????
There must be some hidden files and folder.
Old 04-12-2007, 07:45 PM   #6 (permalink)
i always used to show the hidden files and folder BTW abt which hidden items r u talking?
SUKHI99 is offline
Old 04-12-2007, 09:14 PM   #7 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
"System Volume Information" is a system folder, so you can't open/delete it in NTFS partition bcoz you don't have permission to do so.
To delete/open it, you'll have to take ownership of the folder. Goto its properties and in "Security" tab, take its ownership. (If you don't get "Security" tab, then disable "Simple File Sharing option" in Folder Options).
You can also use following registry code to add "Take Ownership" in file/folder context menu, which will make your task easier.
Link
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 05-12-2007, 11:06 AM   #8 (permalink)
thanx dude ! i'll try 'n' i was waiting for ur reply
SUKHI99 is offline
Old 05-12-2007, 01:11 PM   #9 (permalink)
Krazy_About_Technology's Avatar
System Volume Information folder is, as said by VG, a system folder with permissions only for NTAUTHORITY\System account. You can open it by giving yourself permissions if you are logged on as an admin. This folder stores the files necessary to perform System Restore operations. So if you like to empty it, just press Win+Break key, or Open System Properties from Control Panel, or by right Clicking on My Computer Icon and checking the 'disable system restore on all drives' checkbox. The process is just a bit different for vista.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
Old 05-12-2007, 02:52 PM   #10 (permalink)
Try to create one or two system restore points. After that run disk cleanup.
It will delete the previous restore points except the latest one. So you get the free disk space previously occupied by restore points.
Anyone who has never made a mistake has never tried anything new
sandeepk is offline
Old 05-12-2007, 05:38 PM   #11 (permalink)
You can't delete it manually using windows explorer. To delete , delete the system restore points
ThinkFree is offline
problem in "view" of "folder options" mind021 QnA (read only) 5 23-01-2008 01:43 PM
NEW VIRUS GIVING MESSAGE:"Can not find script file"WIN32.DLL.dll.vbs" ". mdp Software Q&A 5 02-10-2007 02:11 PM
VISTA TUTORIAL: Add "Hide File Names" Option in "View" Menu of Folders Vishal Gupta Tutorials 7 27-06-2007 10:46 PM
"INF Error", VGA Driver "Missing" Installing ATI Catalyst Drivers CannedLizard Hardware Q&A 4 29-07-2006 12:47 AM
- by chris
