Old 03-12-2007, 07:22 PM   #1 (permalink)
superboysahil's Avatar
Exclamation help! How to set up a wireless network?
Hi,
I intend to setup a wireless network so that i can browse internet on psp.
The prob. is that i need to connect via comp. by entering password and username and this cant be done on psp(i think). So wat i want is that wen ever I switch on my Router i automaticly get connected to the internet.
I have a D-LInk Wireless ADSL Router and a BSNL brodband connection(RS.900 unlimited plan).
Plz help
Thanx in advance.
superboysahil is offline
Old 03-12-2007, 07:33 PM   #2 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Default Re: help! How to set up a wireless network?
Switch your modem to Ppoee and enter your user name and password in the modem's configuration page.This way your modem will dial automatically when switched on.Set your pc to always connected to internet.U will now be able to browse internet on psp when u trun on the modem,router and PSP.
For configuring you modem google for help.It will be quiet a task explaining all the details.
Harvik780 is offline
Old 03-12-2007, 08:02 PM   #3 (permalink)
wat shud i enter "VCI" under PVC setting
Here is an image to the setting page
Last edited by superboysahil; 03-12-2007 at 08:02 PM. Reason: Automerged Doublepost
Old 03-12-2007, 08:18 PM   #4 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Vpi-0
Vci-35
Old 03-12-2007, 08:24 PM   #5 (permalink)
thanx.
1 more q. Shall I delete the previous connection.
Old 03-12-2007, 08:26 PM   #6 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
U mean the ones in your modem page.
Preferably,yes,If you bump into any problems just reset the modem.
Wireless network disconnecting. virus_killer Networking 5 11-06-2007 05:48 PM
How to setup wireless Network ssdivisiongermany1933 Hardware Q&A 1 27-03-2007 09:35 PM
Wireless network digitizen Hardware Q&A 2 30-11-2006 12:53 PM
- by chris
