Old 01-12-2007, 01:17 PM   #1 (permalink)
Default Strange problem in displaying commas
Hiii everyone.....i am having a strange problem...my os is not showing any commas in between numbers for ex it must show 324,111 but its showing 324111 ......i'm also attaching screenshots just look at them..
Is this a problem or a simple error with any software
Hari_04415 is offline
Old 01-12-2007, 02:10 PM   #2 (permalink)
troubleshooter
bluepearl's Avatar
Default Re: Strange problem in displaying commas
which is your OS?
try something with control panel
may be some regional settings, currency,etc.
bluepearl is offline
Old 01-12-2007, 05:59 PM   #3 (permalink)
I'm using WinXP with SP2 installed
but in ctrl panel i din't find any such settings
Old 01-12-2007, 07:38 PM   #4 (permalink)
I see right through you.
Sykora's Avatar
Make sure your Locale is set to US_en. That can be done through the accessibility option in contrl panel, I think.
I didn't make the world, I only try to live in it.
http://lucentbeing.com
-- Sykora --
Sykora is offline
Old 07-12-2007, 06:09 PM   #5 (permalink)
troubleshooter
bluepearl's Avatar
hey there's a setting called Regional and Language Options in control panel
set the region to India and lot of other settings !!
check them out
make sure u r in classic view for control panel
Old 09-12-2007, 07:55 PM   #6 (permalink)
Mad and Furious
redhat's Avatar
Go to Control Panel -> Regional and Language Options
There, under regional options, is a "Customize" button.
Click on it, then under Numbers,
Select Digit Grouping Symbol to ","(Comma), and select the grouping type you want...
redhat is offline
Old 09-12-2007, 11:58 PM   #7 (permalink)
Have you recently installed Internet explorer 7.0, Create a Restore point and and remove it, then check for the problem.
speedrider - The ultimate
speedrider_100 is offline
Problem in displaying LAN icon in taskbar Hari_04415 Software Q&A 3 18-08-2007 05:57 PM
strange problem!!! prinz QnA (read only) 5 02-08-2007 09:46 PM
Strange Problem anilthomas26 QnA (read only) 7 12-06-2005 12:25 PM
Strange! very strange..!! Where is the Problem ? Ricky QnA (read only) 8 11-04-2005 04:14 PM
- by chris
