Old 30-11-2007, 09:12 PM   #1 (permalink)
anzaan's Avatar
Unhappy firefox hangs!! help
hi..
my firefox hangs very frquently.. its been such a trouble tat i have shifted to using IE nw.
it started wen i installed the campus edition of firefox. and some add-ons liek stumble.. after tat my firefox keeps hanging after a few mins of use. i tried installing other versions also.. evryone of them bt the problem is still the same.
plzz help..
d a m n ! !
anzaan is offline
Old 30-11-2007, 10:58 PM   #2 (permalink)
Default Re: firefox hangs!! help
installing too many addons can cause this.
Faun is online now
Old 01-12-2007, 01:18 AM   #3 (permalink)
anzaan's Avatar
k.thnx.
bt which add -ons u particularly talking abt?? have u faced such problm??
d a m n ! !
anzaan is offline
Old 01-12-2007, 07:12 AM   #4 (permalink)
Originally Posted by anzaan
k.thnx.
adding addons in one go causes this.
Install them one by one and keep th necessary ones.
Faun is online now
Old 01-12-2007, 11:50 AM   #5 (permalink)
New
New's Avatar
Switch to Opera.. It rocks.....
New is offline
Old 01-12-2007, 02:24 PM   #6 (permalink)
anzaan's Avatar
Smile Re: firefox hangs!! help
thnx i uninstalled a few of them. lets see if tat works...
k.. else willl chk opera.
thnx for ur posts ppl
d a m n ! !
anzaan is offline
Old 01-12-2007, 02:42 PM   #7 (permalink)
Cool G5's Avatar
Are you using Firefox 3 beta 1?I think it has some stability issues.Mine also crashes frequently,even though i haven't installed any plugins.I too suggest switch to Opera.
Cool G5 is offline
Old 01-12-2007, 03:15 PM   #8 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
You must be using firefox 2.5 consider upgrading it and it will work fine
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
krates is offline
Old 02-12-2007, 01:07 PM   #9 (permalink)
anzaan's Avatar
i unistalled some add-ons. still its hangs (bt it happend jst after it upgraded itself )...
opera is an option.. bt i m nt sure if it has similar add-ons. wl miss firefox add-ons man.
d a m n ! !
anzaan is offline
Old 02-12-2007, 01:23 PM   #10 (permalink)
Cool G5's Avatar
Don't worry about plugins opera has all plugins inbuilt.Opera also has some advanced features like mouse gestures,speed dial etc.
Once you use it,you will forget firefox.
Cool G5 is offline
Old 03-12-2007, 04:52 PM   #11 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
@anzaan ...... can u make a list of ur extension & post ?
& which version of ff r u using ? post all details so as 2 get a solution quicker ....
... W H O T ...
ax3 is offline
Old 05-12-2007, 01:32 AM   #12 (permalink)
anzaan's Avatar
Post Re: firefox hangs!! help
k..here it is
add-ons installed:
1) stumble
2) flashgot
3) download helper
4) video download
5) download acelerator integrated
6) talk back
i tried using 2.0.0.11 and even older versions till 2.0.0.4.. bt still it hangs.
i unistalled stumblen n talkback.. still no help. rather nw it doesnt even starts!!
kindly help...
d a m n ! !
anzaan is offline
Old 07-12-2007, 05:02 PM   #13 (permalink)
ax3
ax3's Avatar
aare baaba re ..... long list ..... uninstall "download acelerator integrated" .... will solve ur problem ......
& did u delete ur OLD profiles 2 ....... if not then create a new 1 & then install 1 by 1 extensions & c .........
... W H O T ...
ax3 is offline
Old 08-12-2007, 03:26 PM   #14 (permalink)
anzaan's Avatar
kie... wl do n chk.
hey.. wat u mean by old profileS??
d a m n ! !
anzaan is offline
Old 08-12-2007, 06:13 PM   #15 (permalink)
Wandering In Tecno Land
Ecko's Avatar
Good Problem
Either
Restart in safemode & then disable all extensions
Re-enble them 1 by 1
Use Flashgot or Downthem all instead of download acelerator integrated
Or
Install Mr. Tech local Install
Then make all extensions compatible wid it
Born in Windows Die In Linux © 2009-10 All Rights Reserved.
Learn Linux : www.linoob.com (Official WebSite)
Ecko is offline
Old 09-12-2007, 12:48 PM   #16 (permalink)
ax3
ax3's Avatar
@anzaan ...... old profiles = users .......
when u install ff, u create a default profile [username] ..... folder where ur cache\internet history is saved .......
delete that folder & create a new 1 ......
run dos prompt = cmd.exe = firefox.exe-profilemanager .......
... W H O T ...
ax3 is offline
Old 09-12-2007, 11:56 PM   #17 (permalink)
Use Safari it rocks!!! i am loving it!!!
speedrider - The ultimate
speedrider_100 is offline
Old 14-12-2007, 02:00 AM   #18 (permalink)
anzaan's Avatar
@ax3...u solved it buddy...
i deleted all the profiles, most of the addons.. tat intgretion of download accceleraor... now it hasnt hanged yet...
i m just hoping for good...hehe..
thnx nway ppl
d a m n ! !
anzaan is offline
XP hangs ComputerUser Software Q&A 2 15-10-2007 05:55 PM
PC hangs on [A]bu QnA (read only) 11 19-04-2007 09:47 AM
PC Hangs abhi99_iitg Hardware Q&A 5 30-06-2006 08:39 PM
Hdd hangs up cyrux Hardware Q&A 1 21-06-2006 12:30 PM
Logfile of HijackThis v1.99.1 .... firefox hangs help ...... iinfi Internet & WWW 13 24-05-2005 12:15 AM
- by chris
