Old 29-11-2007, 02:23 PM   #1 (permalink)
Exclamation oracle 8i installation on xp
hi friends
plz help me how to install oracle 8i on xp systems after installing i given scott and tiger password and system,manager but its not working plz tell me procedure
Ravi.Y
yrakesh78 is offline
Old 29-11-2007, 05:35 PM   #2 (permalink)
Default Re: oracle 8i installation on xp
see if there is any process named TNSLNR.exe running in task manager
Faun is online now
Old 29-11-2007, 05:41 PM   #3 (permalink)
troubleshooter
bluepearl's Avatar
what are u using to login rakesh?
SQL Plus ?
did u provide any password during installation?
bluepearl is offline
Old 30-11-2007, 03:45 PM   #4 (permalink)
Exclamation Re: oracle 8i installation on xp
no after installation is completed i given the user name first time its connects next time onwards unable to connect........
Ravi.Y
Old 30-11-2007, 05:39 PM   #5 (permalink)
What is the error message? Something like unable to connect..?
Anyone who has never made a mistake has never tried anything new
sandeepk is offline
Old 30-11-2007, 10:54 PM   #6 (permalink)
hey buddy u didnt replied to my question ?
I ask again is there any process named "Tnslsnr.exe" is running in Task Manager, if not then please take the pain to start the "Tnslsnr" service.
Can u be more specific what error code is displayed?
Faun is online now
Old 30-11-2007, 11:00 PM   #7 (permalink)
dOm1naTOr's Avatar
me too haf trouble after installation
I installed both ones including client nd server.
Now which one shud i open for performing SQL Plus?
And the usermane pass which i geve during installation dun work.
And whats is this 'host string' which is asked during login?
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 30-11-2007, 11:20 PM   #8 (permalink)
Is it oracle 9i ??
You should hav gone with standard install.
FATALITY is the database name that will be having tables created by u.
scott/tiger is the default username/password, it should work.
no need to enter host string.
Host string is use for client accesing oracle on network
Faun is online now
Old 01-12-2007, 12:46 AM   #9 (permalink)
dOm1naTOr's Avatar
@T159
its version 8.1.6.0.0
scott/tiger is not workin.
G3: XPS M1530 |
FZ 16.
Old 01-12-2007, 07:10 AM   #10 (permalink)
@T159
whats the error code ?
Faun is online now
Old 01-12-2007, 02:01 PM   #11 (permalink)
troubleshooter
bluepearl's Avatar
check the installation folder or start menu for something like start database or start service then try logging in !!
guys if u gonna use Oracle just for study purposes,
use Oracle10g XE (200 MB)
it is very simple and light weight !!
it works thr browser as well as cmd line
Old 01-12-2007, 02:35 PM   #12 (permalink)
Ok try out this
Click on "Start" -> "Run" and enter "cmd"
sqlplus scott/tiger@FATALITY
where SID is FATALITY in case of aravind_n20
Faun is online now
Old 01-12-2007, 03:17 PM   #13 (permalink)
GaurishSharma.com
gary4gar's Avatar
use 9i or any later version the latest being was recently revealed by oracle is oracle 11g, it offers many benefits over previous versions. if i correctly remember it supported grid computing. and is altogether faster than previous versions. also you can try MySql.its also nice.
Also oracle 8i is supported on windows 2000.
and oracle 8 personnel edition of win 98
gary4gar is offline
Old 01-12-2007, 04:03 PM   #14 (permalink)
yeah 9i and above are best, JAVA JDBC connectivity is much easier.
My SQL is good one but then in our college Oracle 9i is installed.
My SQL doesnt support procedures and subqueries.
Faun is online now
ORACLE 10g installation ???? cool2c43 Software Q&A 7 27-02-2007 02:37 PM
ORACLE 9i installation whizkrive Software Q&A 22 11-10-2006 01:37 PM
Oracle Installation in Win XP Mitesh Software Q&A 4 02-04-2005 12:03 PM
- by chris
