Old 29-11-2007, 11:54 AM   #1 (permalink)
smile's Avatar
Default Regarding Antivirus Issue
Installing any type of Antivirus ......slows down system???????True or False.... Is true......why so????
SR
smile is offline
Old 29-11-2007, 12:03 PM   #2 (permalink)
Default Re: Regarding Antivirus Issue
True, but only to an extend.
Most anti virus programs use virus signature scanning to detect viruses on your computer. This means that the anti virus program has a list of known virus signatures in it's database, and checks this database each time your PC opens or access any file. Because it can take a few milliseconds to screen every file through a list of many thousands of virus signatures, it is common for an anti virus program to make your computer run a little slower after installation. One measure the effectiveness of an anti virus program is how much it does, or does not slow down a computer after installation.
cool_techie_tvm is offline
Old 29-11-2007, 12:07 PM   #3 (permalink)
smile's Avatar
Heard a lot that Mcafee & Norton Antivirus makes a system very slow than compaire to any other Antivirus
SR
smile is offline
Old 29-11-2007, 12:11 PM   #4 (permalink)
Yes, its true. But the more RAM u have, the less sluggish it will be.
Old 29-11-2007, 12:32 PM   #5 (permalink)
Cool G5's Avatar
True.All antivirus products scan every file u open,copy etc in the background,so there is a little lag in opening of the app.Norton earlier versions were very heavy & used to slow down the system considerably.Newer versions are better.If you find ur sys a bit slow,then you can set the background av agent to low priority,so it won't have a hit on performance.
Cool G5 is offline
Old 29-11-2007, 12:34 PM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
Try Avast if U want free.Else NOD32 is best small antivirus. They eat very small system resource.
And dear...not only antivirus, but installing any software will eat little system resource.
ravi_9793 is offline
Old 29-11-2007, 12:47 PM   #7 (permalink)
smile's Avatar
hm.........thanks a lot guys
SR
smile is offline
Old 30-11-2007, 01:07 PM   #8 (permalink)
New
New's Avatar
If you want free go to Avira(detection rate is close to Kaspersky) else Kaspersky is the good solution...
New is offline
Old 02-12-2007, 02:01 AM   #9 (permalink)
Alive Again...
satyamy's Avatar
if you have a Slow system than go for NOD
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Old 02-12-2007, 09:40 AM   #10 (permalink)
I wont reccommend a Norton on any system. That AV is total ****.
Phenom II 955 BE @ 4.12 Ghz | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Seagate : 1 TB | NZXT Phantom 410
Elite 335 Cabinet @ 0.8K http://www.thinkdigit.com/forum/baza...ite-335-a.html
Tech_Wiz is offline
Antivirus Issue thewisecrab Software Q&A 27 08-12-2006 04:11 PM
in which issue of digit can i get avast and avg antivirus??? tango_cash Software Q&A 7 30-08-2006 08:02 PM
RAM Issue.. dreams Hardware Q&A 13 26-01-2006 08:51 AM
Norton Antivirus 2005 vs Symantec Antivirus Corporate Curious Guest Software Q&A 1 23-04-2005 08:37 PM
- by chris
