Old 26-11-2007, 01:43 PM   #1 (permalink)
Elevating Humanity
The Conqueror's Avatar
Default Strange website problem
Hi friends,
I am facing a strange problem
Every time I type a name of website/open a website in any browser, it says SERVER NOT FOUND.If i Refresh the page for 2-3 times it opens.....
is it some spyware/virus ? if yes then plz tell me the name of virus/spyware
Regards,
The Conqueror
The Conqueror is offline
Old 26-11-2007, 06:08 PM   #2 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
Default Re: Strange website problem
May be some problem with DNS cache!
though not sure!
And once the site opens after 2nd or 3rd attempt, does it load properly?
गीक होना माँगता
victor_rambo is offline
Old 26-11-2007, 08:06 PM   #3 (permalink)
goto start > run > cmd
type
ipconfig /all
paste the output here, maybe we can examine if your configuration is correct.
Also you might be interested in checking if some unwanted addons are loading in your internet explorer.
Open Internet Explorer
Goto Tools > Manage Addons
See if you find any strange ones there or else paste a screenshot of that screen here.
BSNL Launched EVDO / 3G service in India. Checkout updates on it @ www.bsnlevdo.com
ashokjp is offline
Old 26-11-2007, 08:10 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
Originally Posted by Harry Potter
Hi friends,
r u on a slow connection???
ravi_9793 is offline
Old 27-11-2007, 05:54 PM   #5 (permalink)
Elevating Humanity
I am on home ul 900
problem is fixed now...i formated xp works fine now.....
Regards,
The Conqueror
Strange HDD problem g_goyal2000 Hardware Q&A 7 25-05-2008 08:03 PM
Strange problem in LAN sainit Networking 2 13-08-2007 11:49 AM
Strange USB problem ... _timbuktoo Peripherals 3 18-06-2005 11:45 PM
Strange Problem anilthomas26 QnA (read only) 7 12-06-2005 12:25 PM
Strange! very strange..!! Where is the Problem ? Ricky QnA (read only) 8 11-04-2005 04:14 PM
- by gforz
- by Piyush
