Old 25-11-2007, 05:38 PM   #1 (permalink)
Still Shining!
Lucky_star's Avatar
Default Desktop icon problem...
When I select any icon from the desktop, all the icons above it get selected automatically, as if I am holding SHIFT while clicking...
How to resolve it?
Nokia N86 8MP
Lucky_star is offline
Old 25-11-2007, 05:46 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Desktop icon problem...
your XP has gone mad
Restore your XP to best known time.
ravi_9793 is offline
Old 25-11-2007, 06:06 PM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
Even if you are not, but system is detecing the keyboard shift button is pressed down..
So please tell us doesit happen only in desktop or in all other location under explorer window ??
some time Shift key do get pressed down while u dont notice... so check that also...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 25-11-2007, 06:14 PM   #4 (permalink)
The Devil's Advocate
iMav's Avatar
try typing something with caps disabled if the text comes in all caps that means that the shift key is messed up
http://beingmanan.com
iMav is offline
Old 25-11-2007, 06:51 PM   #5 (permalink)
How to resolve it?
Make sure that the filter keys option is turned off. for this Go to Start->Control Panel->Accessibility Option.
In the keyboard tag, make sure that filter key option is uncheck.
goldy_connect is offline
Old 25-11-2007, 08:14 PM   #6 (permalink)
Still Shining!
Lucky_star's Avatar
@goldy_connect, I had tried with all the accessibility options. But no help.
@iMav, while typing there is no problem. So, I don't think shift key is the culprit.
@Choto_cheeta, I have tried with another keyboard. But still the problem persists. It happens in the desktop only.
@ravi_9793, system restore is turned off. So, I think, there is no other option left other than installing Xp again...
Actually, this problem is with my friend's system.
I know that it is a feature in XP. In my keyboard(iBall's-iKey), there is a "MARK" button. If I press it once, this feature gets activated. After that whatever I click, all the icons above it get selected. Even if, I click on some text, all that's above the cursor gets selected. To turn this feature off, I have to press the "MARK" button again...
But in his system, there is no such button. So I don't know, how this got activated. I think there is some key combination, which was accidently pressed. Accesibility options doesn't have this setting.
Nokia N86 8MP
Show desktop icon gone kantiman QnA (read only) 2 12-09-2007 12:55 PM
ubuntu desktop icon overlapping sariq Open Source 13 07-12-2006 09:16 AM
Disappearance of Recycle Bin icon from the desktop Kerry QnA (read only) 1 25-02-2006 07:25 PM
desktop icon toolbar naveenpoddar QnA (read only) 6 25-05-2005 11:11 AM
desktop icon problem goobimama QnA (read only) 16 05-03-2005 01:14 AM
- by gforz
- by Piyush
