Old 24-11-2007, 07:49 PM   #1 (permalink)
a_k_s_h_a_y's Avatar
Default does FDM completely integrate with Firefox ??
i had a question Free Downlaod Manager is not completely intgerated with Firefox ..
many of my downloads start with Firefox download manager..
and not with FDM..
why ??
only few start off with FDM
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
a_k_s_h_a_y is offline
Old 24-11-2007, 08:09 PM   #2 (permalink)
Arrow Re: does FDM completely integrate with Firefox ??
IN MY OPINION FDM COMPLETELY INTEGRATE WITH FF
CHECK INTEGRATION STATUS
OPTION > DOWNLOAD OPTION > MONITORING
AND
SKIP FILE EXTENSIONS ALSO
hotspicyhot is offline
Old 24-11-2007, 08:17 PM   #3 (permalink)
Default Re: does FDM completely integrate with Firefox ??
no i don't have any such options
all downloads fron sourceforge and forums are being missed by FDM
not only that even the .mp3 files direct download links
Old 24-11-2007, 09:04 PM   #4 (permalink)
Om Ma Ni Pä Me Hum
phuchungbhutia's Avatar
it does integrate with ff but not with opera ... so i use orbit with opera which is not that great but ok .....
Om Ma Ni Pä Me Hum: (perfection of-)
Om: generosity,- Ma: pure ethics,-Ni: tolerance n patience.- Pä: perseverance,- Me: concentration,-Hum: wisdom... Using Opera Mini Airtel NOP
phuchungbhutia is offline
Old 24-11-2007, 09:17 PM   #5 (permalink)
NP : Crysis
xbonez's Avatar
i've been using FDM with ff, and each n every dl till date has started with FDM
xbonez is offline
Old 24-11-2007, 10:08 PM   #6 (permalink)
Beware of the innocent
ilugd's Avatar
try installing the flashgot extension
Life is too short. Have fun.
ilugd is offline
Old 24-11-2007, 11:32 PM   #7 (permalink)
TheSaint
NucleusKore's Avatar
YES it does, and @ilugd flashgot helps
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 25-11-2007, 07:53 AM   #8 (permalink)
ArZuNeOs's Avatar
It is integrated......But i am having helluva time with it.....
some times when u click the link ....it begins dld & in the end the file is .php based & not the exact file....lol
ArZuNeOs is offline
Old 25-11-2007, 10:03 AM   #9 (permalink)
TheSaint
That usually happens from sites like sourceforge where the link is actually for international mirrors. I workaround this problem by
1. Clicking cancel for the link captured by FDM and then the firefox download dialog box opens-> save file.
2. As it is saving Select the download link from the dialog box with your mouse. If you have set FDM to monitor clipboard it will capture the link, else highlight drag and drop into the download basket.
Old 25-11-2007, 08:10 PM   #10 (permalink)
ilugd's Avatar
gigaget works like a charm with the flashgot extensions. Just my two cents
ilugd is offline
Old 26-11-2007, 12:44 PM   #11 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
do download the latest from its site .........
or get flashgot extension 4 ff .........
it works like heaven .......
... W H O T ...
ax3 is offline
Integrate SP1 into Vista DVD bajaj151 Software Q&A 11 24-09-2007 12:50 AM
integrate photoshop yoursnayak Software Q&A 2 20-10-2006 03:35 PM
How to integrate sp1 with windows xp shivaranjan.b Software Q&A 13 17-08-2005 07:49 PM
Integrate XP CD with Sp2 !! plsoft Software Q&A 2 18-03-2005 08:19 PM
How to integrate SP1 with Office 2003 siddharth_menon Software Q&A 1 31-12-2004 11:07 AM
- by gforz
- by Piyush
