Old 24-11-2007, 06:05 PM   #1 (permalink)
smile's Avatar
Default Folders are not opening
hi guys,
A strange problem is happening in my drives.i have 4 partitons c: d: e: & f:.I have stored all my softwares dumps(setups) in F: .Now the problem is when i click them nothing is happening..its not opening. I scan my system but no use...the system not hanging... but when i click on the folders in F: its not opening.... What can be the problem...Can anyone help me
SR
smile is offline
Old 24-11-2007, 06:20 PM   #2 (permalink)
Default Re: Folders are not opening
What is the file system of this f: ?
cool_techie_tvm is offline
Old 24-11-2007, 06:28 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Are you able to open the folder by right-clicking on the folder and select "Open" or "Explore"?
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 24-11-2007, 06:32 PM   #4 (permalink)
smile's Avatar
File system is NTFS...No if i right click or explore also no use its not opening
SR
smile is offline
Old 24-11-2007, 07:34 PM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
Type the drive letter as c:\ in address bar.That will open the drive.But this is not the solution.
Try restoring ur XP to best known time.That should fix your problem .
And that is a virus problem.
ravi_9793 is offline
Windows Live Folders : opening soon ! anandk Technology News 19 02-08-2007 07:35 PM
2 folders of same name on dvd swap_too_fast QnA (read only) 6 05-04-2007 05:03 PM
odd folders........! indrajit QnA (read only) 57 25-11-2004 11:59 PM
what to do with these folders harshagarwal QnA (read only) 8 02-08-2004 07:14 AM
- by gforz
- by Piyush
