22-11-2007, 08:49 PM
Attacked by Virus.. Help!!!
Hi all..
My system was recently attacked by a virus. it is giving me continuous alert messages that the pc is infected by some viruses and performance has been reduced. I scanned with spybot and it tracked a trojan called "virtumonde.generic" and "virtumonde". the description said that it would create random named dll files and connect them to winlogon.exe file. I scanned with mcAfee antivirus. It scans the dll file in system32 folder and says that it is a "vundo" virus. but when It is not able to clean/delete/move the file. I tried several ways in safe mode etc. I installed the Avast antivirus and scanned. but after all this was done, the notification problem was fixed but the dll file is being created again and again. so, the virus must be residing still. I also scanned with adaware it reported some errors, cleaned them but still the dll file problem is not solved. Please help me out. The Avast site specifies the vundo virus in 2007 list. but the avast is not detecting it. Please help.. Doesnt avast detect viruses in dll files? Is there a better alternative or should I format, reinstall the os?
My config: AMD Athlon x2 5600+, Asus M2NPV-VM, Transcend 2x1GB 800MHz, XFX 8600GT 256MB, Seagate 250GB SATA2 + Seagate 500GB SATA2, LG 1752s LCD, Sony DRU v200A DVDRW, Logitech MX518, iBall Benz cab
22-11-2007, 08:53 PM
Re: Attacked by Virus.. Help!!!
it looks that a great virus attack u..
u may try to kill them by antivirus but ultimately i think u will have to format the drive as a great dangerous virus had attack in ur pc...
wait for other comments.
lets see what they say...
22-11-2007, 09:00 PM
Did u try scanning your PC using the online scanner of kaspersky??
Here is the link, try it : http://www.kaspersky.com/virusscanner
It should help in cleaning up to an extent.
23-11-2007, 01:02 AM
seems some biological entity....rofl..nevermind
try stopping system restore
and
scan using kaspersky online scanner or
Antivir free edition with updated definitions
And its always good to have defense net like thing to prevent such attracks.
23-11-2007, 02:31 AM
try NOD32 antivirus or AVG
if nothin helps get a backup data n format d drive.
23-11-2007, 04:12 AM
Formatting would be a good option!!!! either you can try online virus scans like - trend micro or safety.live.com
speedrider - The ultimate
23-11-2007, 04:49 AM
Unmountable Boot Volume
Listen, it's a virus called smit fraud. And I can assure you that no anti-virus software can take care of it. Not Norton, not mcafee, not kaspersky, not avast, not spybot S&D, not nod32. NOTHING of that sort will help you with this! This gets into the system in all places, files, registry, startup, it even closes out of internet explorer if you try to get to a website that has remotely got anything to do with anti-virus.
What you need to do is search for a program called 'smitfraudfix'. Download the DOS executable program and you'll need to run it in safe mode. Please search on the internet for the exact instructions because if you screw with it the wrong way, you might loose all data!
Webhosting for Rs12/month!!
http://www.thinkdigit.com/forum/showthread.php?t=74717
http://www.outpowerhosting.com
23-11-2007, 05:05 AM
23-11-2007, 09:14 AM
23-11-2007, 09:28 AM
TechTin.com
1) Install one good antivirus and 2 good antispyware.
2)Update both antivirus and antispywares.
3) Boot in safe mode.
4) Turn off system restore.
6) Do full system scan with both antivirus and antispywares.
7) If possible do online scan.You can find few listed here:
http://www.techhunt.org/node/72
23-11-2007, 09:37 AM
The Smaller Bang
try a bootable antivirus. its the best solution.
Apple iPad 2 16GB WiFi
24-11-2007, 12:40 AM
Guys, I'm telling you, I've been through this, nothing else in the world will fix it permenantly, you need 'SmitFraudFix' to fix it, like I mentioned in my previous post, no antivirus, nothing else will get the job done!
