Old 22-11-2007, 08:19 AM   #1 (permalink)
Wise Old Crow
blueshift's Avatar
Default Urgent help- cant log in-registry problem
Last nite while editing registry i accidently deleted USERINIT registry: C:\WINDOWS\SYSTEM32\USERINIT.EXE
so today when i try to log in i am logged out before i see the desktop.
plz help me to revert the settings back.
http://twitter.com/blueshift155
blueshift is offline
Old 22-11-2007, 09:49 AM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Urgent help- cant log in-registry problem
can you boot in safe mode...........
I am scared..you need to repair your XP using XP Recovery Console.
ravi_9793 is offline
Old 23-11-2007, 05:23 PM   #3 (permalink)
Wise Old Crow
blueshift's Avatar
yes can boot in safe mode too.
But still that login screen comes up and i m logged out.
I m goin to reinstall XP on different partition.
Just another question. Will I lose the data on an already existing partion if I install XP on tht partition?
registry problem..! magneticme200 Software Q&A 8 21-09-2007 08:52 PM
Infected Registry Problem Ecko Software Q&A 1 10-06-2007 09:48 PM
Registry problem in windows XP bipshee1234 Software Q&A 4 25-04-2007 08:01 PM
Windows Registry problem.......... uchiha.sasuke Software Q&A 14 23-02-2007 08:52 PM
registry problem iinfi QnA (read only) 5 07-02-2005 01:14 AM
- by gforz
- by Piyush
