Old 21-11-2007, 01:19 PM   #1 (permalink)
144
144's Avatar
Default Network Copy problems
Our 'Home network' is having problems. The network is made via a D-Link DIR-635 Wireless Router, which shares our ADSL connection, and also is used for file sharing.
There are problems copying files from one computer to another:
THE SOURCE SYSTEM:
The source is on a Windows Vista Ultimate System with a Core2Duo E6600, Intel DP965LT main board. The source pc is connected to the LAN via Ethernet and connected at 100Mbps.
THE DESTINATION SYSTEM:
The destination is on Windows XP Pro SP2, with a AMD Sempron 2400+ platform and MSI main board. The folder on the destination folder is shared, with full read and write access. The Destination pc is connected to the LAN via a wireless adapter from D-Link (USB adapter), connected at 54Mbps
The source file on I:\ cannot be copied to the shared folder on the destination system. The error says, cannot copy from source, not accessible.Initially the file starts to copy after a long delay of around 15-30 seconds and the transfer rate as shown on the source pc is around 200kb/s to 80kb/s. After completing around 8-12% of the copying, it fails. Trying to copy the file from the AMD platform also did not work.
Can anyone direct on who I should go about, to solve this problem?
On a long enough timeline, the survival rate for everyone drops to zero
144 is offline
Old 21-11-2007, 01:36 PM   #2 (permalink)
Default Re: Network Copy problems
Make sure you are logged in on an admin account. Open a command prompt and type the following commands pressing enter after each command. This should enable guest access to all file shares and their subfiles/folders.
net user guest
net user guest /active:yes
cool_techie_tvm is offline
Old 21-11-2007, 07:08 PM   #3 (permalink)
144
144's Avatar
I am sorry. These commands are not executable.
144 is offline
Old 21-11-2007, 07:24 PM   #4 (permalink)
Search for Adventure
ITTechPerson's Avatar
Can u copy any other file? If Yes then u can look for a spyware - if No then pls try from the other end I mean try to copy from the host to destination & vise-varsa both way.
Nobody is Perfect. I am "Nobody"
ITTechPerson is offline
Old 21-11-2007, 08:02 PM   #5 (permalink)
144
144's Avatar
I have already tried copy a file from the destination to source. It didn't work either. And the problem is not with copying only one file
144 is offline
Old 21-11-2007, 11:41 PM   #6 (permalink)
is the connection remains there all the time.check signal strength.try with updated drivers.
jay_jay is offline
Old 22-11-2007, 12:20 PM   #7 (permalink)
144
144's Avatar
I've tried with upgraded drivers for the Wifi adapter, and the signal strength is always above 70%.
144 is offline
Old 22-11-2007, 12:40 PM   #8 (permalink)
anand1's Avatar
One thing you can do .
Now every drive in the PC which is connected to the network is by default shared named as Hidden Shares.
You can check it in any of the source or destination PC by goig through...
My Computer-Right Clik-Manage-Shared Folders-Shares
There you will find the Drive letters with a dollar sign like C$ thish shows that your systems C:\ drive is by default shared.
Now you can harnesh this default share in your case.
Just go to Start-Run-type-\\(your source ip address of the PC)\I:\ and press enter. You will be prompted for admin name and password and you can now share it and can do anything from it. For example \\192.168.1.5\c:\
But remember to set the password for the admin in both the PC
Technology On The Fly
anand1 is offline
Old 23-11-2007, 05:25 AM   #9 (permalink)
144
144's Avatar
Tried, Did not work either
144 is offline
Old 23-11-2007, 05:35 AM   #10 (permalink)
THE SOURCE SYSTEM:
Ok, Boot both the computers in safe mode with networking and then try to access or copy the files and see what happens?
speedrider - The ultimate
speedrider_100 is offline
Old 26-11-2007, 06:51 PM   #11 (permalink)
also try to remove the shares & share again with full control (alow user to edit my file) on both the systems
Am i a Copy-Cat?? Abhishek Dwivedi Chit-Chat 14 07-11-2007 08:02 PM
LAN network problems Liggy Software Q&A 4 22-07-2007 07:25 AM
how to copy Dvd to Hdd kjuvale QnA (read only) 6 17-06-2007 12:15 PM
TOTAL COPY-Copy Stuff In A diff Way! rakeshishere QnA (read only) 17 28-02-2007 09:39 PM
copy from dvd shivi4 Software Q&A 1 02-07-2006 02:06 PM
- by gforz
- by Piyush
