Old 21-11-2007, 12:18 AM   #1 (permalink)
9437077259
go4saket's Avatar
Default Audio Video Sync Problem...
HI guys!
I use Auto Gordian Knot to convert my MPEG2 videos to XVID format. The problem is that where most of the videos are properly encoded, a few of them have audio video sync problem. Why does this happen and what can be done so that this doesnt happen.
The settings that I use are as follows...
Output Resolution : Auto Width
Output Audio Type : CBR MP3 128 Kbps
Output size : Approximately 10-12 MB per minute of video.
Please help.
Thank you.
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
go4saket is offline
Old 21-11-2007, 12:12 PM   #2 (permalink)
Default Re: Audio Video Sync Problem...
for correcting it open the clip in virtual dub.set both audio and video direct stream copy
A) If the difference between audio and video is constant throughout the video:
*From the "Audio" dropdown menu, select "Interleaving" * Under "Audio skew correction", set an appropriate number of milliseconds (positive or negative) in the box labelled "Delay
audio track by"
* Save with a new filename
B) If the difference increases as the movie plays:
* From under the "Video" dropdown menu, select "Framerate" - and select "Change so video and audio durations match"
async occurs due to some delay prblm assosiated when converting ac3 to mp3.if u open it in dgindex u can see the assosiated delay
jay_jay is offline
<Please Suggest> .dat to .avi without audio sync problem a_medico QnA (read only) 1 21-07-2007 02:43 PM
how to sync audio and video in an avi file? freebird Software Q&A 5 21-02-2007 08:01 PM
Audio Video synchronising Problem dabster Open Source 6 09-07-2006 09:13 PM
problem with audio video rohit2468 Software Q&A 8 06-07-2005 07:58 PM
Divx Audio Sync Prob klinux QnA (read only) 2 28-10-2004 03:25 AM
