Old 19-11-2007, 09:11 AM   #1 (permalink)
nil_3's Avatar
Default Problem in running Adobe Audition 3
Whenever I try to run Adobe Audition 3, it says:
"Runtime Error. The application has requested the Runtime to terminate in an unusual way. Please contact the application's support team for more information".
The same dialog shows when I run Adobe Audition 2 but it smoothly runs Adobe Audition 1.5. My OS is Windows Vista Ultimate. What are the possible reasons for this Runtime Error?
The Adobe Audition 1.5 and 2 runs properly in Windows XP with SP2. I did not check Adobe Audition 3 in Win XP.
P4 3.0GHz Dual-core.
Intel 945GNT MoBo.
1GB RAM.
Seagate 160GB SATA HDD.
HP 16X Dual Layer DVD Writer.
Coloursit 450Watt SMPS with NAVTECH cabinet.
Samsung SyncMaster 740N TFT LCD 17" monitor.
nil_3 is offline
Old 19-11-2007, 09:21 AM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Problem in running Adobe Audition 3
I have heard there is some compatibility issue in windows vista.
Update your windows vista through live update...this may solve your problem.
..OR wait till vista SP1 is released.
Also try to tun without any plugin.
ravi_9793 is offline
Old 22-11-2007, 08:03 AM   #3 (permalink)
nil_3's Avatar
No luck despite installing updates! Any more suggestions please.
Intel 945GNT MoBo.
1GB RAM.
nil_3 is offline
adobe photoshop problem.please help. quan chi Software Q&A 12 08-11-2007 09:35 PM
Adobe Cs3 installation problem Kaushal Hiwarkar Software Q&A 1 18-09-2007 11:12 AM
Adobe Illustrator9 Problem arnab_raha1989 Software Q&A 1 28-12-2006 09:33 AM
Adobe illustrator problem SE><IE Software Q&A 11 10-12-2006 02:46 AM
Record your old audio cassetes with Adobe Audition 1.5 rajat22 Tutorials 1 27-06-2005 10:45 PM
- by gforz
- by Piyush
