Re: Sound and vista home basic....proble
Does the problem comes only when you play DVDs? Try playing a MP3 in Winamp and check if it runs. In case no sound is coming at all Check if your drivers are updated. Cables are properly plugged in correct places and also the Volume Control nob "Check the Volume and the state of Mute Checkbox]
In case problem is coming jsut for DVDs then I dont have much clue.
Phenom II 955 BE @ 4.12 Ghz | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Seagate : 1 TB | NZXT Phantom 410
Elite 335 Cabinet @ 0.8K http://www.thinkdigit.com/forum/baza...ite-335-a.html
