Old 17-11-2007, 01:42 PM   #1 (permalink)
Default double clicking D drive
when i double click on D drive, the 'open with' dialog box open
and to open it i have to right click on drive and click on explore to open that drive
ajit.naik is offline
Old 17-11-2007, 02:21 PM   #2 (permalink)
smile's Avatar
Default Re: double clicking D drive
Scan the D: with antivirus or
copy d: data to some other drive and format it .....this may solve the problem
SR
smile is offline
Old 17-11-2007, 02:34 PM   #3 (permalink)
Google Bot
Pathik's Avatar
Explore D drive and del autorun.inf in that drive..
It may be hidden..
Or run CMD and type "del f:\autorun.inf"
Pathik is offline
Old 17-11-2007, 02:55 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
yes..
and remember to turn off system restore before you delete it.
www.9zap.com/forums -> Indian Webmaster Forum
whost.in - Web Hosting Offers
thinkdigit.com/forum/showthread.php?t=109137
TechTin.com
ravi_9793 is offline
Old 17-11-2007, 06:07 PM   #5 (permalink)
try this it will work
erase aurorun.inf /f /a -r
and restart your computer
try it will all drive that have this problem
himanshumaker is offline
Old 18-11-2007, 08:45 AM   #6 (permalink)
jacques's Avatar
Hi All,
I am fasing the same issue. I red some troubleshooting artical from google and did. But it rose new issue.
Troubleshoot i did
Go to tools> folder option> file type > Select drive option > clicked on advance and choose find > ok
Now whenever i click on a drive It opens search option.
Suggest what to do?
jacques is offline
Old 18-11-2007, 08:56 AM   #7 (permalink)
TechTin.com
ravi_9793's Avatar
Originally Posted by jacques
Hi All,
Troubleshoot i did
Suggest what to do?
[Windows] FreQuently AsKed ProBlems WITH SoluTions...
Point No. 2
TechTin.com
Old 18-11-2007, 03:13 PM   #8 (permalink)
smartygoldenfish's Avatar
dont worry bro!
its windows fault!
can be solved easily
open regedit from run
open HKEY_CLASSES_ROOT and then got to directory
delete ALL the entries inside directory on LEFT side
except backgroung, shell, shellx, default icon
restart
smartygoldenfish is offline
Old 18-11-2007, 11:11 PM   #9 (permalink)
sumeetindia's Avatar
disable "hide protected OS files" from the folder options
delete all the "autorun.ini/autorun.inf" from the drive roots
restart your PC if they are again created the probably your PC is infected with virus
Sumeet
www.fultoomobile.com - Free Hindi Ringtones and mobile wallpapers
sumeetindia is offline
Old 23-11-2007, 08:59 AM   #10 (permalink)
jacques's Avatar
Originally Posted by ravi_9793
I have tried the steps, but there is no go..................
jacques is offline
Old 23-11-2007, 09:22 AM   #11 (permalink)
TechTin.com
ravi_9793's Avatar
start-->>run-->>type this command and press enter
regsvr32 /i shell32.dll
Restart system.Should solve problem.
TechTin.com
c drive not opening on double clicking kooabs03 Software Q&A 16 17-11-2007 06:09 PM
Double clicking a drive in my computer will launch the dos command dir Amit Kumar Saini Software Q&A 1 18-10-2007 06:10 PM
Double clicking on drive opens search! DizitalNovice QnA (read only) 6 24-05-2007 12:01 AM
Help me pls.. Application doesnt start after double clicking abhi99_iitg Software Q&A 3 23-09-2006 04:53 PM
