Old 16-11-2007, 03:04 PM   #1 (permalink)
smile's Avatar
Default how to install 3 operating system
hello guys
i have 80 gb ..i have 4 partitions each 20 gb....i want to install 3 opearating systems....ie:win98, win2000 and win xp...Can any one tell me the procedure how i can install
SR
smile is offline
Old 16-11-2007, 03:08 PM   #2 (permalink)
"The Cake is a Lie!!"
[xubz]'s Avatar
Default Re: how to install 3 operating system
Why do you want to do that? It would make no sense at all you know.
Its better if you install both 98 and 2000 in a Virtual Machine Environment. (like Microsoft Virtual PC 2007)
(i.e. Run Windows from inside Windows)
[xubz] ● http://xubz.com/
[steam_id] ● http://steamcommunity.com/id/xubz
[xubz] is offline
Old 16-11-2007, 03:12 PM   #3 (permalink)
smile's Avatar
hm.........ok but i need to know the procedure whether after installing all the 3 OS whether it will be installed correctly or i will have a problem?????
SR
smile is offline
Old 23-11-2007, 06:00 AM   #4 (permalink)
Ok, First thing first - the process is very simple. Install Windows 98 first on drive c:, Then Windows 2000 on drive D: - Fresh installation, then Windows xp Pro on Drive E: - fresh installation.
Second concern - if you install 3 OS's on the same computer then please be aware of boot.ini crash. it happens because windows 98 became absolute now a days. so beware before any action.
speedrider - The ultimate
speedrider_100 is offline
Old 24-11-2007, 11:42 AM   #5 (permalink)
New
New's Avatar
Why Vista is not there in your list?
New is offline
Old 24-11-2007, 11:45 AM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
may be money problem
It is always recommended from microsoft to install earlier version of windows first.
So,
1) Install win98 on any drive
2) Install win 2000 on any drive
3) Install win XP on any drive
But remembers, no two OS should be installed on same drive.All Os should have separate drive.
Thats it, no special technique.
www.9zap.com/forums -> Indian Webmaster Forum
whost.in - Web Hosting Offers
thinkdigit.com/forum/showthread.php?t=109137
TechTin.com
ravi_9793 is offline
Old 24-11-2007, 01:12 PM   #7 (permalink)
vaibhavtek
Posts: n/a
instal one OS in C: one on D: and other on E:
simple.
but u can use Microsoft Virtual PC 2007 as suggested by [xubz].
it is very good.
Old 24-11-2007, 01:48 PM   #8 (permalink)
Yes one more suggestion for Microsoft Virtual PC.
sanju is offline
Old 24-11-2007, 05:56 PM   #9 (permalink)
smile's Avatar
yes money problem
SR
smile is offline
Old 24-11-2007, 06:04 PM   #10 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
advice: xp sp2 can do all 98 and 2000 can, as long as you have dos. only some old games like motocross madness don't work(why did you give it then, digit?)
Or, you can also go 98 + xp if you love motocross. 2000 is unnessary. replace it with linux or something.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 12-05-2008, 02:48 AM   #11 (permalink)
AND LINUX, MAC, SOLARIS, UNIX AS WELL
marshalll is offline
Old 12-05-2008, 08:43 AM   #12 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
^^ Bumping a six month old thread for a useless comment? reported.
dheeraj_kumar is offline
to install 3 operating systems Pepsi™ Hardware Q&A 15 09-05-2006 06:53 PM
How to Install the Amiga Operating System..... ECE0105 Internet & WWW 3 13-03-2006 01:04 AM
Operating system vegeta_killer Open Source 1 10-07-2005 08:15 PM
two operating system kumar4141 Internet & WWW 1 02-01-2005 02:28 AM
