Old 15-11-2007, 08:53 PM   #1 (permalink)
Default Pc going mad!!!!
Hi...for the past two three days my pc has gone mad!..I mean literaly it has gone mad.It will be working fine for many hours until suddenly all the graphics will go off crazy...icons will start blinking...all the windows will become white...and so on ...hers my pc's spec..
AMD64 X2 dual core processor 3600
ASUS M2V-MX
NVIDIA GEForce 7300SE/7200GS
2*2 GB Kingston RAM
Guys pls help me out....
yoursnayak is offline
Old 15-11-2007, 09:00 PM   #2 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Exclamation Re: Pc going mad!!!!
Your graphics card is causing the problem. Check ur graphics cards temperature after running the PC for 1 or 2 hours. If it exceeds 70 degree celcius then ur card is in trouble buddy. Check if the CPU's ventilation is rightly implemented. Add a extra fan if necessery.
debsuvra is offline
Old 16-11-2007, 09:34 AM   #3 (permalink)
Default Re: Pc going mad!!!!
how to check graphics card's temp?..
Old 16-11-2007, 09:58 AM   #4 (permalink)
dOm1naTOr's Avatar
use nv temp logger.
look at
www.guru3d.com
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
- by gforz
- by Piyush
