Old 15-11-2007, 11:21 AM   #1 (permalink)
smile's Avatar
Default Cannont Remove Programs
hello guys
i want to uninstall few programs from my system but the problem is they are not uninstalling in Ad Remove Programs.....i tried it in safe mode also ...the error am receving is "cannont find uninstall.dll file".can anyone suggest me what is the problem ?how to rectify it?
SR
smile is offline
Old 15-11-2007, 11:32 AM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Cannont Remove Programs
reinstall that program..and than try to uninstall those.
If that also don't help you..you need to remove manually.
ravi_9793 is offline
Old 15-11-2007, 02:09 PM   #3 (permalink)
smile's Avatar
hm.........can i get free softwares to remove programs
SR
smile is offline
Old 15-11-2007, 02:23 PM   #4 (permalink)
Rubik's Uncle!!
Charan's Avatar
Looking at all of your other posts here in digit... looks like your system is flooded with lotsa virus.. format you hdd and create a fresh install. if you donot know how to do it then get professional help.
Charan is online now
Old 15-11-2007, 03:08 PM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
yaa..there are many freewares.Just google it.
But I am scared, they may not also help you because, if any file is missing..you cant do anything.
Old 15-11-2007, 03:59 PM   #6 (permalink)
smile's Avatar
Is there any other way to remove
SR
smile is offline
Old 15-11-2007, 04:20 PM   #7 (permalink)
TechTin.com
ravi_9793's Avatar
you can remove manually.
Old 27-11-2007, 04:42 PM   #8 (permalink)
smile's Avatar
remove manually means ur telling me to delete the folders in c:\program files
SR
smile is offline
Old 27-11-2007, 05:44 PM   #9 (permalink)
101101
Use the software CCleaner to remove programs.It works perfectly.
Finding answers is simple, all you need to do is come up with the correct questions.
crystal_pup is offline
Old 29-11-2007, 01:12 AM   #10 (permalink)
smile's Avatar
ok fine...........will try anyway thanks for all of you
SR
smile is offline
Uninstall programs, not listed in add/remove programs Aanand QnA (read only) 9 06-06-2008 07:00 PM
Add/Remove Programs Gone in Edgy ~Phenom~ Open Source 10 04-01-2007 05:24 PM
Want to remove few programs that run during start up Aanand QnA (read only) 5 25-10-2005 11:37 PM
i am being prompted to go to Add or Remove Programs prashanthmpai QnA (read only) 5 21-10-2005 09:47 PM
Add or Remove Programs... satya_gen QnA (read only) 2 19-07-2005 07:23 PM
- by gforz
- by Piyush
