I want to connect to net through my mobile Nokia 6030 having airtel connection .I have installed Modem.But when I go to "
Control Pannel/ Network connection/create new connection'.
New Connection Wizard Open, there only last option is enabled i.e, "
connect using a braodband connection that is always on" the other two option i.e,
Connect using a dialup modem and
connect using a braodband connection that requires a user name and password is disabled.
Plz tell me how to enabled that two option or any other way to create a dialup connection then only I wll be able to connect to net. Plz help
