Old 13-11-2007, 09:31 AM   #1 (permalink)
zatomas's Avatar
Default HD is running out
Hello all ….
I am running windows xp @ home I have about 5 users all are limited users I need to limit the access and usage of hd space “too much chunk is always been downloaded to the d drive” ……
Is there any way to deny or limit their access to my d drive…?
Or can I set certain amount of disk space for each user…
Thanks for the help…
Helooooooooooooooooooooooooo
zatomas is offline
Old 13-11-2007, 10:30 AM   #2 (permalink)
Default Re: HD is running out
u can try out disk quota management if ur partitions are ntfs
Faun is offline
Old 13-11-2007, 12:04 PM   #3 (permalink)
smile's Avatar
DISK QUOTA IS GREAT .....AND UR PARTITION SHOULD BE NTFS
smile is offline
Old 13-11-2007, 10:40 PM   #4 (permalink)
zatomas's Avatar
its ntfs but the documents and setting is on the c: drive or dose it not matter....
can users have theire own folders on the d???
zatomas is offline
Old 13-11-2007, 11:09 PM   #5 (permalink)
yes
jay_jay is offline
Old 17-11-2007, 11:31 PM   #6 (permalink)
zatomas's Avatar
thankx for this guys just some time @ windows help and i got it done
zatomas is offline
running OS X on PC setharsh QnA (read only) 20 02-04-2007 02:50 PM
is cpu n gpu running hot? xbonez Graphic cards 8 30-03-2007 10:58 AM
COD not running. What to do???? q3_abhi Gamerz 2 16-06-2005 04:28 PM
Running Far cry Tommygecko Gamerz 4 26-04-2005 04:52 PM
What are we Running After ? vswizard QnA (read only) 15 10-05-2004 10:17 PM
- by gforz
- by Piyush
