Old 12-11-2007, 08:36 PM   #1 (permalink)
mr_fanatic's Avatar
Default Please Help: Virus and Hardware Problem
Hello Guys,
Straight through the point, my 1st problem is the hard disk drive issue. Although i can fully access or browse the hard disk drive, the computer always gives a USB/Flash Drive icon on the system tray. Take a look at the screenshot below and you'll see what i meant.
The Hard disk drive capicity is 160 GB manufactured by Hitachi running on Windows XP Service Pack 2.
My 2nd problem is caused by a virus (i guess). Here is the screen shot below. I'm not sure whether its a virus or not, but i will be very thankful if someone could give me a tips.
Thanks.
mr_fanatic is offline
Old 12-11-2007, 08:54 PM   #2 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Default Re: Please Help: Virus and Hardware Problem
Well for the first problem, check in ur device manager where do the Hitachi HDD situated? It should be in the hard disk drive section. R u using a USB drive encased in a casing ? Also check http://www.fixya.com/support/hitachi/ to get support.
Regarding your second problem, I think that it is not a virus, rather it is happening due to the theme u set up for xp. I think it is just a change of language in the view section. Remove the theme and re check.
debsuvra is offline
Virus problem, need online virus checking details-pls hava a read here. mobileman Software Q&A 2 14-04-2007 10:58 AM
A wierd problem.(Probably virus or hardware problem) spyder Software Q&A 2 09-01-2007 06:52 PM
Please Help Someone!!!! hardware problem. The Unknown Hardware Q&A 9 23-11-2006 07:02 PM
hardware problem dd1907 QnA (read only) 1 25-08-2005 10:41 PM
mcafee virus scan 8.0 - problem updating virus definations infra_red_dude Software Q&A 3 26-06-2005 11:43 AM
- by gforz
- by Piyush
