Old 10-11-2007, 12:15 PM   #1 (permalink)
Default NERO 8 Installation Problem
i Couldn’t install nero 8 from digit DVD. because installer showing this error.
" A system reboot was requested by a previous software installation (e.g. a Windows Update).please reboote your computer to resume the installation of Nero 8 "
I restart system but problem is same. & I have no any previous nero software.
pritam2007 is offline
Old 10-11-2007, 02:03 PM   #2 (permalink)
The Researcher
Default Re: NERO 8 Installation Problem
did you uninstall previous version?
Ramakrishnan is offline
Old 10-11-2007, 02:10 PM   #3 (permalink)
Alive Again...
satyamy's Avatar
Which operation system ?
XP or Vista ?
If you are installing it in Vista than Read this
http://www.chotocheeta.com/2007/10/2...windows-vista/
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Old 10-11-2007, 11:44 PM   #4 (permalink)
try some more time...it'll work...it happened to me also
yoursnayak is offline
Old 11-11-2007, 02:49 PM   #5 (permalink)
download nero clean tools from nero.com and try again....
sarincv is offline
Nero Installation Problem sesi5674u Software Q&A 3 15-09-2007 10:18 PM
Nero Installation - any restriction to keep in mind? SGS_001 Software Q&A 2 08-04-2007 02:41 PM
Nero 7 installation and uninstallation error!!!! shyamno Software Q&A 3 06-05-2006 09:53 PM
nero 7 installation problem plabanbehera Software Q&A 2 30-11-2005 06:35 PM
Nero 6 & problem with writing photo cds with nero sarincv Software Q&A 1 09-11-2004 08:22 PM
- by gforz
- by Piyush
