Old 07-11-2007, 10:48 AM   #1 (permalink)
Default Problem with openSUSE
Hey friends, I have logged here after one month. Have anyone of you installed openSUSE 10.3 from digitDVD. I have installed it and have problem that when I start linux from dropp down menu(as I have windows xp also) then a progress bar of white colour comes, when it is completed then the screen goes blank. The installation was successfull without any error. I have reinstalled it several times I think 4 times but the problem persists. Tell me what can b the prob.
abhijangda is offline
Old 07-11-2007, 01:14 PM   #2 (permalink)
TheSaint
NucleusKore's Avatar
Default Re: Problem with openSUSE
press ctrl+alt+F1
type root at prompt
type root password and login
Now at root prompt type yast, and go to hardware->graphics and monitor
and configure your graphics card and monitor from there
After you finish press ctrl+alt+F7 and then ctrl+alt+backspace
NucleusKore is offline
Old 12-11-2007, 11:09 PM   #3 (permalink)
thank you
openSUSE 10.3 Available Now! Dark Star Open Source 77 13-10-2007 06:57 PM
DVD writing problem in OpenSuSE 10.2 aditya.shevade Open Source 5 04-08-2007 05:03 PM
OpenSuSE updater applet problem aditya.shevade Open Source 8 03-04-2007 10:00 AM
OpenSuSE 10.2 and avi files problem... aditya.shevade Open Source 13 28-03-2007 02:08 PM
- by gforz
- by Piyush
