Old 03-11-2007, 06:12 PM   #1 (permalink)
Default Winrar right click options not working
I have reinstalled cleaned registry many times but I cant get this working.
Winrar right click options show but when I choose any option to unzip the file nothing happens, need help in unzip a set of 21 file which are .rar file, is there any other software which can unrar the file?
ranjan2001 is offline
Old 03-11-2007, 06:16 PM   #2 (permalink)
Default Re: Winrar right click options not working
Is it working from the context menu of windows explorer?
ThinkFree is offline
Old 03-11-2007, 07:22 PM   #3 (permalink)
In windows explorer when I right click on the rar files It gives me 3 options, I choose anyone of that & no one options are working.
Old 05-11-2007, 02:26 PM   #4 (permalink)
Try Reinstalling Winrar
devil_himself is offline
Old 05-11-2007, 03:38 PM   #5 (permalink)
anand1's Avatar
Try reinstalling and if you can try to install the latest version of it.
Technology On The Fly
anand1 is offline
Old 05-11-2007, 04:30 PM   #6 (permalink)
Web developer
narangz's Avatar
Execute WinRAR. Now follow these:
1. Click Options -> Settings
2. Select integration tab.
3. Under Shell Integration, select 'Integrate WinRAR into shell' & 'Icons in context menu'.
4. If they are already selected, de-select them press OK & exit WinRAR. Now re-launch WinRAR and select the options in step 3. Press OK & exit WinRAR.
narangz is offline
Old 05-11-2007, 05:04 PM   #7 (permalink)
I thought that your solution should work but it also did not work, I am now assuming something is blocking winrar but surprised as to what is blocking bcoz its working if I left click & open the rar file & manually extract to a directory.
Update:
I uninstalled older version & reinstalled the latest version 3.71, but the problem remains the same.
I can use the context menu to zip the file or zip & email the files but I cant use the context menu for extracting the files.
Any clue what is blocking it or I need some reg hacking to get this working.
Old 05-11-2007, 06:45 PM   #8 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
oh just reinstall your windows or use 7zip kgbarchiver etc etc
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
krates is offline
Old 05-11-2007, 09:10 PM   #9 (permalink)
Thats sounds too easy solution
Old 05-11-2007, 09:46 PM   #10 (permalink)
Web developer
narangz's Avatar
^^ then i guess the only solution will be to clean registry of winrar entries & reinstall winrar. not sure if its gonna work
narangz is offline
Old 05-11-2007, 10:58 PM   #11 (permalink)
krates's Avatar
just uninstall winrar and then open registry cleaner clear your registry and then install it
if still doesn't works
may i ask you a private question is your windows legal
krates is offline
Old 05-11-2007, 11:18 PM   #12 (permalink)
Before posting here thats what I did twice but strange thing it was not working then only I posted here.
YES that what is mentioned on the XP CD with hologram. & I have not done any XP update in last 2 month which might have caused this problem.
Anymore clues to sort out this problem?
Old 19-02-2009, 03:52 AM   #13 (permalink)
Thumbs up Re: Winrar right click options not working
Hi, I installed rarzilla and it fixed it... Yeah, I know sounds unlikely. Anyone clean their registry lately? 'Cos I did and I reckon that screwed something up.
Anyway there ya go, I hope this helps someone, I've had this problem twice before and it's REALLY annoying.
Actually, please reply here if it works for you, I'm curious to know that it's not just coincidence.
Peace and Love.
ItchySox is offline
Right Click = Left Click emailaatif786 Hardware Q&A 6 26-03-2007 02:48 PM
Right Click Options Krish_88 QnA (read only) 6 05-03-2007 11:28 AM
start button right click options Shasta Software Q&A 4 29-01-2007 10:03 PM
REG: mouse right click options.... sree_shan Software Q&A 10 20-10-2006 03:10 PM
commmon port problem in UPS service options(in power options iamtulipin QnA (read only) 1 20-02-2005 11:43 AM
- by gforz
- by Piyush
