Old 03-11-2007, 03:44 PM   #1 (permalink)
bharat_r's Avatar
Default Documents & settings too big???
By documents & settings folder seems to occupy 4GB+ of disk space.
Is this normal?
(image taken using Ashampoo Win Optimizer 2008 )
bharat_r is offline
Old 03-11-2007, 04:57 PM   #2 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Default Re: Documents & settings too big???
Is this normal?
I think u have downloaded much and chosen the Documents and Settings folder to save the downloaded files . If not, check if u have set to download a zip, rar or iso or similar file with large size and did not completed downloading.
debsuvra is offline
Old 03-11-2007, 05:33 PM   #3 (permalink)
a_g = JPKN
s18000rpm's Avatar
do you use ThunderBird orsimilar mail client? if yes- then its normal, coz these mail clients d/l all files (emails) to "Application Data" under your user name.
e.g. TB saves all d/led emails here -> C:\Documents and Settings\<user name>\Application Data\Thunderbird\Profiles
Google earth does the same.
btw this happens when you save files to "My Documents".
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 03-11-2007, 05:39 PM   #4 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
I already told that.
debsuvra is offline
Old 03-11-2007, 05:48 PM   #5 (permalink)
bharat_r's Avatar
Ya I do use thunder bird..guess I'll have to delete all the mails in it... I have it configured for 4 ids!!
and I'll clean up the my documents.Point taken.
Other than that??
bharat_r is offline
Old 03-11-2007, 05:59 PM   #6 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
BTW U showed that ur Docu & sett. folder takes 4GB and from the pic it is 27.40%. Then the total HDD size is
4GB * (100/27.4) = 14.6GB
However, the pagefile size is usually varies between 1.5 to 2 GB and from the pic, it is 4.43%. Thus the Total HDD space is
maximum      2GB * (100/4.43) = 45.15GB
minimum     1.5GB * (100/4.43) = 33.86GB
Isn't it too confusing to see only one HDD's various sizes.
I don't think that Thunderbird is a problem, unless you have very big files as emails. Because, I also use it and has 5 Gmail address in it with about 500 emails. And I am sure that no space more than 10MB is taken, believe me it's only 10MB.
debsuvra is offline
Old 03-11-2007, 07:33 PM   #7 (permalink)
bharat_r's Avatar
hey lots of math !!
The partition size of C drive is 20 GB(shows as 18.6 GB)..
I installed Vista transformation pack & uninstalled it...
I suspect Vista transformation pack has done something. Maybe left something behind after uninstall?
btw I have Vistamizer installed..
bharat_r is offline
Old 03-11-2007, 09:51 PM   #8 (permalink)
a_g = JPKN
s18000rpm's Avatar
thats coz maybe you dont get much attachements
see this
Old 03-11-2007, 10:30 PM   #9 (permalink)
Commander in Chief
QwertyManiac's Avatar
Hm, run a disk cleanup, and then go to the folder with hidden files enabled and clear out whatever you think is junk (Mostly under Application Data there exists old application Setup files [For repair], you can clean that and maybe Vista Trans. Pack as well)
QwertyManiac is offline
Old 04-11-2007, 03:13 PM   #10 (permalink)
TheSaint
NucleusKore's Avatar
One more thing, there is one Dr Watson kernel debugger file (text file icon). It will usually be in documents and settings->all users. I do not know what the hell it is, but sometimes I have seen it become 2 GB in size. Reasons?? Anyway then I go to command prompt and delete the file and reboot the system.
NucleusKore is offline
my documents gone niku_19jan Software Q&A 17 18-03-2007 06:03 PM
My Documents src2206 Software Q&A 13 29-06-2006 11:12 PM
Moving the Documents and Settings folder... thestrategist Software Q&A 7 28-05-2006 12:24 PM
Securing 'My Documents'? aryayush Software Q&A 8 06-04-2006 05:13 PM
C:\Documents and Settings\abc\Local Settings\temp remove it? Huzefa QnA (read only) 6 03-07-2005 10:58 PM
- by gforz
- by Piyush
