Old 03-11-2007, 03:07 PM   #1 (permalink)
Default need a dvd to vcd converter- reg
hi friends,
be kind to share a dvd to vcd conveter.
I m having some dvds. if I m gettingi can make them to watch frm my home vcd player naa.
be kind to help.
thanking u.
mobileman is offline
Old 03-11-2007, 03:33 PM   #2 (permalink)
Default Re: need a dvd to vcd converter- reg
For a list of DVD to VCD Softwares-
http://www.videohelp.com/tools/sections/dvd-to-vcd-svcd
Step by step guides-
http://www.dvd-guides.com/content/view/56/59/
http://www.angelfire.com/ex2/mgvcd/index.html
sunny155 is offline
Old 31-03-2008, 10:59 AM   #3 (permalink)
Guide for DVD or vcd Ripper and convert to portable player
what is DRM
DRM is an acronym for Digital Rights Management, a broad term used to describe a number of techniques for restricting the free use and transfer of digital content. DRM is used in a number of media, but is most commonly found in video and music files. There are many who argue that DRM is a misnomer, since it deals with use issues rather than the rights of the consumer. They therefore reinterpret DRM to stand for Digital Restrictions Management.
While DRM is most frequently used for movies, it is gaining more widespread use in other media as well. Audio files purchased through many online stores, such as Apple's iTunes Store, have various DRM schemes built in to limit the number of devices they may be played on. Many producers of eBooks are using a similar implementation of DRM to limit how many computers a book may be viewed on, and even how many times it may be viewed. In mid-2005, a number of content producers for television began requesting DRM of their shows via the popular TiVo system.
Therefore,if you want to free enjoy movie oraudio anywhere and anytime,first you should crack it whit some tools and then convert them to your portable player!
there is one tools,which is very easy for beginner.
1.Download the program from Pavtube DVD Ripper rip DVD to AVI, DivX, MPEG, VCD, DVD converter and run it. Then you can see the main interface.
2.Click the Load DVD button or Load IFO button, and a dialog box pops up for you to select the original DVD movies. Here, you have added the DVD movies to the product.
3.After adding the DVD movies, you can click “+” to open sub-directory: the titles and click “+” again: the chapters. Here, you can select the chapters you like to rip.
4. Hit the button under the view screen, click the play button, and preview the original movie chapters. Also, you can get the thumbnail from playing video with one click for collection on your PC.
5.Select one format for playback on portable devices by click the triangle button. From the drop-down bar, you can get what you want. Then specify where to save the ripped movies by selecting from Output box.
6.Edit the videos by clicking Customize buttons:
Effect:
Click Effect tab, you can come to the following interface.
In this menu, drag the small button to adjust the brightness, contrast, flip, or the volume. Also it offers the option to select Apply to child chapter.
Trim:
Click Trim tab, you can come to the following interface.
Here it is optional to decide on the start time and end time. With the function, you can get the video you
wish.
Crop:
Click Crop tab, you can come to the following interface.
If you want to cut off the black edges, please click the triangle button and choose the way to cut from the
drop-down bar. In addition, you can select the image origin as required manually by dragging the frame-mark
or adjust the number about length and width of the image.
7.The advanced settings are provided for the experienced users. You can click Settings button to set the
parameters like bit rate, frame rate, video size, and so on.
8.Click the run button to start ripping the movie.
9. After finishing ripping task, you can hit Open button to find the ripped files quickly and directly. Then
it is ready for transferring them to your iPod, iPhone, Zune, PSP, Apple TV, 3GP for playback on them.
jane1043 is offline
mp4 converter sarincv QnA (read only) 6 23-10-2006 07:19 PM
mp3 to amr converter Spawn Freak Mobiles and Tablets 2 14-08-2006 01:59 AM
PDF to PDB converter mako_123 Software Q&A 1 15-09-2005 06:23 PM
- by gforz
- by Piyush
