Originally Posted by JohnephSi
Plz tell me the settings to connect 2 computers through lan.
to play lan multiplayer game.
I have made the setting bt when i go view workgroup computers it sayv mshome is not acessible ...... .Plz help me to connect lan between my laptop n pc.
No big Deal!
Just make sure that both the pcs are on the same subnet(?). To do that, just ckeck the IP addrs of you laptop, pc. (i hope u know what a ip is!). [go to command prompt and type ipconfig to find your ip]. The first n second part of of both the ips must be same! if no,make them same.
Or just keep the ips of both systems identical except for the last digit. (like 1.1.2.1 and 1.1.2.2).
You must not have any problem now.
And may i now which game are you gonna play? Coz I'm also a gaming freak!
