Scheduler not running in Vista
i am facing a strange prob in my vista ultimate in which the scheduler service has to be run manually and when i try to change it to run automatic from the services panel then the option of automatic is greyed out. Is it a known problem....
Also can anyone tell me that if i want to run a particular exe file as service during start up of windows is it possible... i dont want the application to be visible in the task bar anywhere..
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
