Old 29-10-2007, 11:19 AM   #1 (permalink)
Exclamation help on DM111-p netgear
folks i hav a dataone broadband connection and was usin utstar300r2 modem but lately it has started showing signs of over usage . i bought a new netgear dm111p modem . had been tryin long for gettin it connected in vain . the internet light doesn just glow . settings are all fine 0 & 35 mtu 1483 . diagnostics show ppp server failure but i am able to connect using utstar. i use a laptop and connect it through ethernet port .
royalbull is offline
Old 29-10-2007, 12:49 PM   #2 (permalink)
Attitude matters
Ponmayilal's Avatar
Default Re: help on DM111-p netgear
Netgear DM111p is known to be problematic. You may refer to Vista prb!! where another digitician is having problems with the same modem. You are well advised to return the modem to the seller and get a Dlink or any other modem which is known to work with BSNL broadband.
Ponmayilal is offline
Netgear Wi-fi Router problem chits Hardware Q&A 4 24-11-2007 11:23 PM
Netgear WG511v2 on Debian Issues sachin_kothari Open Source 12 28-06-2007 10:55 AM
- by gforz
- by Piyush
