Originally Posted by apacheman
well, i've tried removing dat hotfix but it gets worse bcuz VTP 7.0 duznt even start afta dat. n many programs depend on dat hotfix like .net etc. wot do i do now...?
Forget about your VTP 7 now. Do one think goto windows update and it will scan your computer and ask you to update you can update your computer again with that hotfix so everything gets back to normal. Wait till Mid November for VTP 8 which has more Vista like features and a lot of Major Bug Fixes.
If you can
buy the latest Windows Blinds than you need not have a VTP tool. Just install Windows Blind and it has one inbuilt skin called vista put that thing on and your WinXP will turn into Vista type interface. It supports transperancy and everything so give it a try.
