what is it relation with system restore...?
Windows is by default comes with System restore (Xp or later), system restore will keep backup of all softwares programs including if its a Virus / Spyware...
where as all Anti Maleware programs lik Antivirus, antispyware doesnt get permission to touch the System Restore directory... so even any AVS detects a treat running and cleans it, as soon as u reboot the Viruses usually comes back from the system rstore directory
when you close system restore, bydefault windows deletes all restore point hence any virus/malware stored there
so its recomended by microsoft to close system / turn of system restore if u are running full system scan
http://support.microsoft.com/kb/831829
tell me onething how will i use this spybot,,,
Download from
http://www.spybot.info/ install
update when u install as it would ask you to do
then simply run a full system scan like a AVS
it will detect any spyware if present and will clean it by it self
