Old 22-10-2007, 09:23 AM   #1 (permalink)
WOW... are you?
gsoul2soul's Avatar
Default Services or installation problem ?
Well... I don't know what or which to blame !!
I recently installed my Win XP !!
It's like somethings gone bad or something... well when i try to install or uninstall programs they won't happen
And then i would have to Manually start the "windows installer"
Same goes for my "Ipod" i will need to start the service... manually... or else my itunes says "software not properly installed"
What could have happened ?
I mean the Services are by default in "Manual"... but why won't it initialize when i install or uninstall programs and software
Help... please
Should i repair my win XP ?
Well I found my problem... just posting so that you all might be aware!!
apparently i had disabled the service "DCOM Server Process Launcher"
Which resulted in my *Windows installer not working
*Ipod not getting detected
*word document not opening properly
* And mp3 not opening in winamp automatically
Everything well now...
Take care
gsoul2soul is offline
Old 22-10-2007, 05:16 PM   #2 (permalink)
Smitten by Computers..
raptorz's Avatar
Default Re: Services or installation problem ?
Leave the system services to automatic not manual.
There were somethings Man was never supposed to know, for everything else there is Google..
raptorz is offline
Old 25-10-2007, 11:29 PM   #3 (permalink)
New
New's Avatar
have you disabled any services?
New is offline
Old 25-10-2007, 11:48 PM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
His problem's solved.
QwertyManiac is offline
XP installation Problem devgujar Software Q&A 15 09-08-2007 01:55 PM
Generic Host Services Problem ashstud_83 Software Q&A 13 16-03-2007 08:13 PM
Win 98 Installation Problem arifmohd786 Software Q&A 6 13-07-2005 11:43 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
Windows XP Services Problem sandeeprao Software Q&A 1 27-04-2005 10:24 PM
- by Niilesh
