Old 20-10-2007, 10:13 AM   #1 (permalink)
9437077259
go4saket's Avatar
Default Problem In Excel...
Hi Guys!
I have a small problem with Excel. If I type a huge number in any cell, say "777777777777777", it automatically gets converted to "7.77778E+14". I dont want this to happen and want it to be displayed normally. How can I stop this from happening.
Chao...
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
go4saket is offline
Old 20-10-2007, 10:18 AM   #2 (permalink)
Dreamweaver
Gigacore's Avatar
Default Re: Problem In Excel...
this is just because the word length or the bit is limited to 16 bits
Gigacore is offline
Old 20-10-2007, 10:26 AM   #3 (permalink)
9437077259
go4saket's Avatar
So does this mean that I cannot use a large number in Excel sheets. BTW, which is the largest number supported by 16 Bits...
Win 7 Ultimate
go4saket is offline
Old 20-10-2007, 10:40 AM   #4 (permalink)
Dreamweaver
Gigacore's Avatar
i really dont know. . . but try those numbers in Calculator too you will get the same . . . . you can get more info about 16 bits in wiki
Gigacore is offline
Old 20-10-2007, 12:02 PM   #5 (permalink)
mekalodu
iinfi's Avatar
well try this ...
right click on the cell (or range of cells) where u want this number to be displayed..
goto format cells >> number tab >> number option in the list box >> select "0" in decimal places.
click on OK ..
is this wat u want ??
mekalodu
iinfi is offline
Old 22-10-2007, 03:04 PM   #6 (permalink)
The Researcher
Just format the cell in number format. If you get ###### like this, increase the width. That is all.
Ramakrishnan is offline
Old 23-10-2007, 12:01 AM   #7 (permalink)
ayush_chh's Avatar
guys i too have problem in excel.....
what i want is, to enter a date in one cell and get the date after 30 days in some other cell automatically....how can i do this???
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 23-10-2007, 03:02 PM   #8 (permalink)
The Researcher
press + and go the cell containing the first date again press + and 30 and enter
Suppose you don't get in date format format in "date"
function problem in excel march27 Software Q&A 1 20-09-2006 04:44 PM
Excel(ent) problem! nil_3 Software Q&A 2 23-12-2005 08:55 PM
MS Excel worksheet columns not SORTING-PROBLEM MERGED CELLS TVB RAJU Software Q&A 1 29-07-2005 12:50 PM
Problem With Excel ravimevcha Software Q&A 3 03-04-2005 04:11 PM
