Old 17-10-2007, 01:04 PM   #1 (permalink)
GaurishSharma.com
gary4gar's Avatar
Wink **{Post optimun settings For torrents}**
I have been searching for guides with optimal settings what there aren't any for my ISP(BSNL), i am sure there are lot of BSNL users there so please help post your settings. as a matter of fact i never get full speeds which my connection is capable off. always get slower.
Follow this format
ISP & Plan:
Max speeds Possible(up/dl):
Torrent client used:
Port number(TCP/UDP):
HTTP seeding enabled(Yes/No;if yes then provide details):
Encryption Enabled(yes,no):
Max speeds Client(up/dl):
Max Global Connections:
Max connections per torrent:
Upload slots:
b]Any comments & other details you would like to add[/b]:
Actua Speed you are getting:(test & post screenshot):
By this thread i aim to make a directory of settings which gives high speeds every ISP .
So let me start
ISP & Plan: BSNL Home 500
Max speeds Possible theoretical(UP/DL):512kbps/2048kbps
Torrent client used:Azureus 2.5.0.4(linux)
Port number(TCP/UDP):53333/53333
HTTP seeding enabled(Yes/No;if yes then provide details):No
Encryption Enabled(yes,no):No
Max speeds gettings in torrents(UP/DL):55kbps/1250kbps
Max Global Connections:150
Max connections per torrent:40
Upload slots:2
Any comments & other details you would like to add:Capped upspeed in azureus at 55kbps and download speeds is Unlimited
Actual Speed you are getting(test & post screenshots)
Now its your turnhyeah:
gary4gar is offline
Old 17-10-2007, 02:21 PM   #2 (permalink)
Default Re: **{Post optimun settings For torrents}**
http://www.speedtest.net/result/193506504.png
manmay is offline
Old 17-10-2007, 02:44 PM   #3 (permalink)
GaurishSharma.com
gary4gar's Avatar
Originally Posted by manmay
Please this a not a speeds test thread
Also wasting your comapnies valuable resources is not good
gary4gar is offline
Deathly Hallows Released : Post Comments (Don't post Spoilers) Quiz_Master Chit-Chat 142 31-07-2007 10:49 PM
C:\Documents and Settings\abc\Local Settings\temp remove it? Huzefa QnA (read only) 6 03-07-2005 10:58 PM
