Old 15-10-2007, 06:03 PM   #1 (permalink)
sanjeed007's Avatar
Default port forward
how to portforward coz in utorrent sometimes the (/.\) or the red sign comes below.when i try to portforward i set up everythin but i am not able to so the last step coz it is not there in my router settings
my modem-utstar300r2u
connect-BSNL HOME500 PLAN
i setuped the static ip (from 192.168.1.2 to 192.168.1.136)and followed every step but got stuck in the last step of port forwarding
http://img517.imageshack.us/img517/2295/untitrk3.jpg
i use utstarr2u as my modem
and here is the screen of the advanced settings .it does not have the virtual server screen at all
http://img488.imageshack.us/img488/4982/untitlgn0.jpg
pleas help me
sanjeed007 is offline
Old 15-10-2007, 08:41 PM   #2 (permalink)
Pee into the Wind...
shady_inc's Avatar
Default Re: port forward
Did you try http://portforward.com/ ??
Life is as complicated as you say it is.
shady_inc is offline
Old 15-10-2007, 08:44 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
Shady_Inc ... His first screen-shot is from Port-Forward website
Harsh J
www.harshj.com
QwertyManiac is offline
Old 16-10-2007, 07:13 AM   #4 (permalink)
sanjeed007's Avatar
Originally Posted by shady_inc
obviously i tried portforward.com
Old 16-10-2007, 07:41 AM   #5 (permalink)
TheSaint
NucleusKore's Avatar
Then in your torrent client enable uPnP. Do the same in your router, and forget about port forwarding.
NucleusKore is offline
Old 16-10-2007, 01:34 PM   #6 (permalink)
shady_inc's Avatar
Ahh...My bad!!Didn't have a look at screenies since net was acting funny. .
@ sanjeed007: You can try setting up DMZ mode.This will open up all ports for anyone.This can be a security risk if you have got services running on those ports.Or else it's just fine and to easier to set up than port forwarding.
Old 16-10-2007, 02:19 PM   #7 (permalink)
sanjeed007's Avatar
how to set up dmz mode.nothin is runnin on thesse ports i think
Old 25-10-2007, 11:27 PM   #8 (permalink)
sivarap's Avatar
I have a config like this
Laptop -> wireless router -> BSNL huwaei modem --> internet
I've setup port forwarding in wireless router. now should I setup the same for huwaei modem? does the connection goes out the same port from wireless router? somebody H....E....L....P
pleas help me
Did u check in the advanced tab?
sivarap is offline
Old 26-10-2007, 12:12 AM   #9 (permalink)
"The Cake is a Lie!!"
[xubz]'s Avatar
The Newer UTStarCom Modems have their Telnet Interface Menu (the Shell Works, but the menu is removed) and Port Forwarding Page Removed!
You can apply the firmware from Beetel Modems. Both use the same Processor and Chipset. But I donno if that works correctly.
[xubz] ● http://xubz.com/
[steam_id] ● http://steamcommunity.com/id/xubz
[xubz] is offline
port forward mtnl router-plz help iamitp Networking 1 14-05-2007 01:11 AM
Help me to port forward in my Router thilina Networking 8 15-01-2007 06:51 PM
How to Port forward on Cable Broadband.. shyamno Broadband and DTH 3 03-12-2006 08:01 PM
want to forward port gau_pppu Hardware Q&A 3 18-11-2006 11:26 AM
How to Forward a port in Router. fordac Software Q&A 7 01-11-2006 04:08 PM
