Old 15-10-2007, 01:00 PM   #1 (permalink)
Default [HELP] PROBLEMS using Fedora 7
Today i installed the Fedora 7 provided by digit in july issue. Installation executed smoothly. I am using linux for the first time.
I was trying to mount windows partions. Tried a lot to mount. Read guides and tutorials online. But its not loading. Could there be a problem with the OS ? Or its just me ?
Nothings happens after i issue command in terminal. Cursor moves to next line and keeps blinking.
Just for confirmation could u tell me how to mount ?
sda1,sda5,sda6 are my window based partitions and sda8 is my linux.
suhas_sm is offline
Old 15-10-2007, 01:37 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: [HELP] PROBLEMS using Fedora 7
If cursor moves to the next prompt without an output, it means your command was successful.
What File System are your partitions, FAT32 or NTFS? I can write a small script to ease your work if you let me know that.
Harsh J
www.harshj.com
QwertyManiac is offline
FEDORA problems azzu Open Source 3 05-08-2007 04:30 PM
Beryl problems on fedora 6 cranky Open Source 8 07-03-2007 12:26 AM
Fedora 6 post installation problems cranky Open Source 5 05-03-2007 07:11 PM
RedHat/Fedora problems Aijaz Akhtar Open Source 3 20-06-2005 10:50 AM
Fedora Core 3 problems.... [lokesh] Open Source 18 17-03-2005 01:30 AM
