Old 14-10-2007, 07:45 PM   #1 (permalink)
Exclamation HELP!!! Acrobat8.0 haunting me !!!
whenevr i right click or ctrl+c or ctrl+delete
acrobat 8.0 installation starts..i tried removing the install files..doesnt work..evn if i let it continue..it stops coz it cant find the install files(which ive already deleted)...how do i remove this irritant??? pls help ...
---------Alcohol doesn't solve any problems, but if you think again, neither does Milk.---------
drcaesar is offline
Old 14-10-2007, 07:53 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: HELP!!! Acrobat8.0 haunting me !!!
reinstall acrobat reader 8.0 again at same location..now uninstall it through "add or remove programs" in control panel.
www.9zap.com/forums -> Indian Webmaster Forum
whost.in - Web Hosting Offers
thinkdigit.com/forum/showthread.php?t=109137
TechTin.com
ravi_9793 is offline
Old 15-10-2007, 07:35 PM   #3 (permalink)
problem in acrobat don't worry
try this reader it is best from acrobat and have more features
click the link to download
http://www.foxitsoftware.com/pdf/rea...own_reader.htm
gauravjaryal is offline
