Old 13-10-2007, 10:23 PM   #1 (permalink)
Edburg's Avatar
Default Help ! My system crashing frequently....
My system was overheating frequently(almost 100 dgree celcius) and crashing.....so i cleaned up the pro fans and now the temps are fine(50 C).....
But now my system is again crashing but i dont know why.....no BSODs no errors..not nothing..sytem just goes off and i have to turn off and on the main power supply to restart it.....
The longer i wait(idle-off) after a crash,the longer it withstands the crash.......if i restart immediately,restarts very quickly.....so i think h/w prob may also be involved...
any suggestions welcome....thinking of reinstalling windows if this continues....
Edburg is offline
Old 13-10-2007, 11:08 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Help ! My system crashing frequently....
There can be many reason behind the same:
1) cabinet fan problem
2) SMPS problem
3) Addition of new hardware.
4) hardware driver error
5) Softwares installed problem.
ravi_9793 is offline
Old 14-10-2007, 04:39 PM   #3 (permalink)
Edburg's Avatar
2) SMPS problem
Well i tried to install another copy of windows but even during that installation it crashed....so software prob is out if the questions.....and no new hardware is added......only hardware prob....
i removed the cabinet fan...only pro fan and smps fan running....
i changed the SMPS about a month or two ago....i think now this is the culprit....how can i confirm it ??
the temps and voltage levels using intel active monitor is normal only....
Edburg is offline
Old 14-10-2007, 04:48 PM   #4 (permalink)
dOm1naTOr's Avatar
Check if da capacitors near da proccy are Ok. If it has started cracking at the tips, then mobo is near death.
The problem may also be due to SMPS triping.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 14-10-2007, 07:21 PM   #5 (permalink)
Edburg's Avatar
the capacitors seem fine when just looked at them.....and what is SMPS tripping ??
Edburg is offline
Old 14-10-2007, 07:47 PM   #6 (permalink)
dOm1naTOr's Avatar
when SMPS can't handle da load of the PC
G3: XPS M1530 |
FZ 16.
Old 21-11-2007, 01:26 PM   #7 (permalink)
Edburg's Avatar
ever since my last reply,i have changed 2 smps and then the sys stopped booting .....gave my sys to 2 comp repair walas...they told mobo dead and repairing wud be temp only..so bought a new mobo(unfortunately the only 478 pin p4 mobo available in market was zebronics 845gv )....and also bought a new 256 MB ram
then the old RAM refuses to make my sytstem boot ...so removed it
did a clean format and then installed XP SP2 but in the boot screen it just freezes ....tried several times with diff CDs...then installed win 2000 and XP w/o SPs....installed just fine but the sys is just freezing frequently....and then i have to reboot
seems that wheneevr i give my harddisk some work it freezes but not sure in this....
wht can i do for this ? may i sh8ud have bought a new one when the first symptoms of prob occured...now repair after repair occurs....
Edburg is offline
Old 23-11-2007, 05:41 AM   #8 (permalink)
My sympathy is with you Edburg, Ok before opting for a New HDD u can try to format the HDD completely i mean through disk partition, create new partition delete the existing ones and format the partition, create only one partition then wait and watch still you face the same issue hmm you need to buy a new HDD.
speedrider - The ultimate
speedrider_100 is offline
Old 23-11-2007, 03:41 PM   #9 (permalink)
Edburg's Avatar
^^ thanks for the reply...will try it out soon....
how can i make sure its the hard disk that is the culprit here ?
Edburg is offline
Old 27-11-2007, 12:35 PM   #10 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
do a scandisk [4 bad sectors] .....
& how many threads 4 only 1 problem ..... ya i know its a MAJOR 1 .......
its really frustrating , isnt it .......
... W H O T ...
ax3 is offline
System Crashing Sun_The Power Hardware Q&A 1 11-02-2007 01:26 PM
system crashing tamilvendan QnA (read only) 14 15-02-2006 06:54 PM
System Restarts frequently... ramprasad QnA (read only) 6 19-01-2006 03:15 PM
system hangs frequently legolas QnA (read only) 7 26-10-2005 10:04 AM
- by Niilesh
